I bet the install is similar to the Lloydz TT intake. You can look up the install instructions on his site. One of the small breather filters will be for the crank case breather tube. Cut that hose a little and install the filter on the end. This video by Witchdoctors also shows how to install the TTs. May be of some use. On the TTs, Lloydz states you have to replace the IAV with his IAV, but don't know about the 3rd Gear intake.
