1 - 7 of 7 Posts
Just wondering who has a modulator on their tail light, what brand and what is looks like (Video would be great here)...
Also, what have you done to add lighting to increase your visibility as well as add "Bling"??
I installed a trunk (tail light) modulator on my Vision. (No bulb change was needed or necessary). The Vision Trunk lights now act as turn signalsAND brake lights. They "pulse" three times before becoming steady brake lights.Theadded trunk lighting DOES make atangible difference in visability.
HinshawsVictory in Auburn, WA ordered and installed the "run-turn brake control" but I didn't examine it. However, the part cost was $59.99. My invoice indicates it was part # 4710 but oesn't state the manufactorer. When I take my trunk off, there isa single "plug in" wire to the module in addition to the normal Vision trunk lighting outlet. Talk to "Chris" at 253.939.7164. He ordered the tailight modulator for me it it works very well..
For those who haven't done this mod it is WELL WORTH the 3 hours to do....However, a NOTE for '09 bikes:
While doing the mod based on Firehawks GREAT pdf file. I found one hiccup (I guess only for the '09 models) when splicing the green/pink wire UNDER the seat DO NOT CUT THE WIRE use a tap splice and just use it to feed power to the 4710 module. Then trace the wire bundle up to an area right before it goes up into the tour pack and find the green/pink wire, here is where you CUT IT and place a scotch lock (spade connector) on the wire going UP TO THE TOUR PACK and tape the wire going back towards the main wire harness so it won't short to anything.
Other than that this is a GREAT mod and should make the rear of the motorcycle seen more readily when braking, turning or using the hazard lights.
Reactions: J.Wales
1 - 7 of 7 Posts
