Tachometer kit | Page 3 | Victory Motorcycles: Motorcycle Forums
Tachometer kit
Discussion in 'Victory Cross Roads' started by gtrjoe, Dec 7, 2013.
  1. scooter1
    scooter1 Member
    Jun 6, 2011
    91
    14
    Everything on the bike is metric. I believe it's either 4mm or 5mm.
  2. efasulo
    efasulo New Member
    Aug 21, 2016
    25
    3
    Victory Cross Roads
    I just tried to install the tach upgrade kit on my 2011 XR and no luck. The 2011 CR speedo is larger in diameter than the bracket will hold the speedo.
    The part number is 2877652. It was half price and too good to be true I guess.
    Does anyone know the correct tach kit number that fits the 2011 XR?
    I bought tach kit 2877652 which is the wron part number for the 2011 CR. This is apparently for the 2010 CR and in 2011 and later the speedo is larger in diameter than the tach is. So the bracket seems to be the main difference. If Honda E Toledo still has the part please let me know. I will be listing my tach for sale.
    In prior posts I noticed that part 2878209 fits 2011 and later CR's.
  3. efasulo
    efasulo New Member
    Aug 21, 2016
    25
    3
    Victory Cross Roads
    See my later post. The tach kit for the 2011 and later CR is different from 2010. 2011 and after has a larger diameter spedo.
    Part 2878209 is the correct part number.
  4. efasulo
    efasulo New Member
    Aug 21, 2016
    25
    3
    Victory Cross Roads
    You are correct, thanks for verifying that.
  5. primethious
    primethious Well-Known Member
    Aug 14, 2013
    8,041
    2,478
    2012 Victory Cross Roads
    The tach kit I got for my 2012 XR has a different face on it compared to the earlier model, but the tach is the same size as the speedo. This allows for a left or right installation of the tach.
  6. efasulo
    efasulo New Member
    Aug 21, 2016
    25
    3
    Victory Cross Roads
    Thanks, it does add a nice look with the dual set-up
  7. Luciferiad
    Luciferiad Active Member
    Aug 7, 2014
    352
    158
    Twin Falls, Idaho
    2011 Crimson Cross Roads
    Paulie doesn't have the part. He gave me a list of dealers that did and phone numbers to call. But I really hate making phone calls, and I flipped the cost of the tach into new pipes instead.
  8. efasulo
    efasulo New Member
    Aug 21, 2016
    25
    3
    Victory Cross Roads
    No, part 2877652 is for 2010 CR only. it does not work on the 2011 which I have also. The correct part # is 2878209 and they are becoming hard to find since being discontinued. Just found and ordered one today.
  9. caw391
    caw391 Member
    Oct 21, 2013
    153
    10
    North Las Vegas, NV.
    2013 Cross Roads Classic
    Here are the part numbers you need to search for:
    L.
    VICTORY CROSS ROADS® TACH KIT
    You’ll stay abreast of your Victory Cross Roads® engine’s performance with this Tach Kit. It provides accurate, visible
    RPM readings to help you manage your gear selection and monitor engine operation.
    2877652 ’10 CR
    2878209 ’11-13 CR
  10. efasulo
    efasulo New Member
    Aug 21, 2016
    25
    3
    Victory Cross Roads
    Thanks, the 2878209 model has been discontinued but I located one and have it on order. I am looking forward to the nicer look with more info!!!
    • Winner Winner x 1
  11. efasulo
    efasulo New Member
    Aug 21, 2016
    25
    3
    Victory Cross Roads
    I installed the tach kit today for my 2011 XR. It really looks sharp. Thanks to the other users for the advice and help on the install. With the right tools the bottom hex screws for the headlight came apart without a major problem. IMG_0418.JPG
  12. primethious
    Aug 14, 2013
    8,041
    2,478
    Congrats on the new tach!
    When I installed mine I used a small amount of silicone spray lube to help in assembly.
  13. JeffD
    JeffD Active Member
    Jun 15, 2015
    294
    160
    NE Ohio
    2014 Crossroads 8 Ball
    All of the descriptions say for 2011 - 2013. Anyone know if the kit will work on a 2014? Did they ever make a kit for the blacked out gauge on the 8 Ball?
    Thanks,
    Jeff
  14. FoFo
    FoFo Well-Known Member
    Jun 14, 2016
    1,772
    997
    Fort Worth, TX
    2010 Victory Cross Roads
    Dang it that looks good. Got to get one!
  15. topshelf
    topshelf Member
    Aug 31, 2010
    40
    9
    Kelowna
    Vegas
    I'm looking for a tach for my 2012 Vegas. I wonder if the kit for the 2010 XR would work if its a smaller diameter than the 2011's?
2010 victory cross roads speedometer tach combo 2877652
2013 cross roads tach kit
2013 victory cross roads tachometer
dakota digital for victory crossroads
how to wire up a tach to a victory vegas jackpot
tachometer kit - 2877652
victory cross roads tach kit
victory highball tachometer
victory kingpin factory tach
victory octane tachometer kit
victory tachometer
