Switched 12v in fairing? | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by Alwhite00, Jun 9, 2021.
  1. Alwhite00
    Alwhite00 Well-Known Member
    Sep 13, 2020
    495
    348
    Victory
    I want to hook up my XM to a switched 12v in the fairing. Are there any good spots to tap into or unused plugs there?
  2. PDXLaserGazer
    Jun 3, 2013
    4,359
    1,551
    Molalla, OR
    If you aren't using the GPS connector for a zumo, would be a good place to start.
    I added a Fuzeblock FZ1 so I have 1 switched power line to it and it powers relays so I can put 6 or 7 keyed components in drawing from the battery using only one signal. You can set each output to keyed or always on.
  3. PDXLaserGazer
    Jun 3, 2013
    4,359
    1,551
    Molalla, OR
    Found this on a different thread
  4. Alwhite00
    Sep 13, 2020
    495
    348
    Victory
    What does the GPS plug look like? I see a couple extra plugs in there?
  5. PDXLaserGazer
    Jun 3, 2013
    4,359
    1,551
    Molalla, OR
    Kinda squarish with 5 wires. Mine had a rubber boot on it, clutch side near the temp sensor if memory serves. Blue with green stripe is gnd, red is +12v,
  6. Alwhite00
    Sep 13, 2020
    495
    348
    Victory
    Thanks. I'll check it out.
  7. Pauljp
    Pauljp Well-Known Member
    Nov 28, 2013
    1,261
    795
    Quebec Canada
    2014 Cross County Tour
    The GPS connector on the clutch side of the bike is identical to the cruise control connector located on the opposite side (throttle) of the bike.
    I made a video of the cruise connector for someone earlier. You can see it in my video below.
    The GPS plug looks exactly the same and has a black rubber cover on it. Hope this helps you identify it when you see it.
  8. Alwhite00
    Sep 13, 2020
    495
    348
    Victory
    Thank you.
  9. IndyVictory
    IndyVictory Well-Known Member
    May 29, 2020
    1,371
    501
    Indianapolis
    Just don't use the audio input from the GPS connector for your XM. It's mono only.
  10. Alwhite00
    Sep 13, 2020
    495
    348
    Victory
    I found the 12v wire and tapped into it.
    works great.
    thanks everyone.
