Welcome to the forum.
Also, if you've engaged yer locking mechanism, usin' yer key, ya might have locked yer glove-box. If ya, by chance, have yer steerin' column all the way to the left or right, can't wiggle the handlebars left or right at all then, ya've locked yer bike. To unlock... put the key in the ignition, press down on the key (the metal portion with the key in it should slide down in the lock's channel) now, turn clock-wise. This puts yer key in the OFF position.
The bike won't start, the glove-box should now be accessible by pressin' down on the glove-box cover, and the steerin' column should be free to move. It happens absentmindedly sometimes... after ya've reached OFF (when turnin' the bike OFF), ya press a little bit while turnin' counter-clockwise, the key goes down then, ya remove it. Sure the bike's OFF but ya've also engaged the mechanical lockin' safety mechanism.
I've just changed all the locks on my Vision and found that if the ignition lock's workin' right it's quite easy to enable the safety.
