stock speakers 2015 cct. | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory General Discussion' started by yamaho, Oct 27, 2021.
  1. yamaho
    yamaho New Member
    Sep 17, 2014
    27
    5
    Minnesota
    2015 Victory XCT...All stock except for stage one pipes..
    some times when songs play the songs come through speakers winey . ..its been that way for years. I seldom listen to it any way... sitting in the driveway they sound good but if I do listen to them at lower speeds the winey sounds happen....well off and on. No biggie was wondering if others noticed this who may still use the stock radio systems...
  2. Bikesofbrads
    May 16, 2020
    2,812
    1,752
    South central/eastern ohio
    2015 victory xct & 06 katana
    How are you sourcing the songs, do you mean through the fm radio stations, weather band or when blue toothing? If via blue tooth check ur cable as it’s allowing interference, or a loose ground wire
  3. badtoejam
    badtoejam Member
    Apr 4, 2014
    61
    59
    2013 Cross Country
    Crap in, crap out.....
    Doesn't matter how good a system you have if the source material is worthless. Not saying this is the case in your instance, rather a rule of thumb.
  4. yamaho
    yamaho New Member
    Sep 17, 2014
    27
    5
    Minnesota
    thanks -- just wondered. again Its fine at extended stop lights or waiting in traffic,for keeping company.
  5. yamaho
    yamaho New Member
    Sep 17, 2014
    27
    5
    Minnesota
    thank you i've heard this also.
  6. TwoManyXS1Bs
    TwoManyXS1Bs Well-Known Member
    Dec 20, 2019
    333
    389
    Fredericksburg, TX
    2016 Victory Vegas
    I've discovered strong EMI (radiated emissions) coming from somewhere near the front of my gas tank, which leaks into my audio stuff.
    Audio systems can be sensitive to stray EMI, poor grounding, ground loops, ...etc.
    I've had to replace all my audio-related wiring with shielded cabling. And, avoid using the harness wiring for power and ground (where possible). Google "single point ground" for tech info...
  7. IndyVictory
    IndyVictory Well-Known Member
    May 29, 2020
    1,440
    518
    Indianapolis
    Bad grounds can get engine noise into stereo systems.
    Hopefully you are not still using the OEM speakers they would be blown by now.
