1 - 6 of 6 Posts
A few years ago, I lost the steering post cap bolt [part# 5131497] from my 1999 V92C. Although hard to find, I can still order the OEM part for about $90. Yes, $90 for a cap bolt! However, I'd rather spend $5 or less and replace it with something semi-comparable from ACE hardware.
So, does anyone happen to know the bolt's specifications [bolt diameter, bolt length, thread pitch, etc.]?
This is my best guess:
going by the 14mm driver size the bolt threads would be M16-2.00
I'd get a 100mm long one & see if it threads in by hand & can it can be cut to proper length. It needs a strong/thick (1/4" min) plate washer about 1 1/2" diameter that could be welded to a button head cap bolt to match the original bolt. Torque to 50 ft/lbs
I don’t think you’ll find an exact replacement at Ace, possibly something that will work. That’s why I believe you need to fabricate/weld a plate washer to a button head bolt to replicate the original that has a huge chromed button head-“when in doubt build it stout” is my motto. TC’s had a big ugly hex head bolt but it was hidden under the fairing. Be careful & good luck.
Thanks. I prefer for the bolt to look as much like the OEM bolt as possible. If I wasn't so thrifty, I'd buy the $90 OEM bolt, but I just can't force myself to do that.
1 - 6 of 6 Posts
