Starting issue | Victory Motorcycles: Motorcycle Forums
Starting issue
Discussion in 'Victory Cross Country' started by Wild Bill, Nov 8, 2021.
  1. Wild Bill
    Wild Bill Active Member
    Dec 17, 2019
    192
    96
    Cross Roads
    So much for searching!
    Anyhow, I was out riding all weekend and stopped for sustenance- a few hours later bike wouldn't do anything! At first the lights came on and everything looked normal, hit the start switch and lights out, nothing! A few more tries and the same- lights came on once or twice but not any noise indicating it's trying to start. It was dark and I was close to home so I just ubered- I'll check the battery for loose wires and such but is there anything else I should check?
    Oh, it's a 2011, battery is almost 2 years old and I put 15k on it. I changed the 40w Amp last year.
  2. Pauljp
    Pauljp Well-Known Member
    Nov 28, 2013
    1,283
    818
    Quebec Canada
    2014 Cross County Tour
    If you can, before doing anything else, if you have a meter check the battery voltage at rest. It should be 12.6 volts or slightly higher.
    If it is below that, then your battery is dying.
    Yes certainly check your battery connections, but also check the ground connection at the battery and at the engine casing.
    If the battery is dead, it could simply be the battery or the voltage regulator. Once you get it running check the voltage at the battery again, it should be around 14.5 volts while running.
    Good luck and keep us posted.
    • Agree Agree x 3
  3. Wild Bill
    Dec 17, 2019
    192
    96
    Cross Roads
    Thx Paul, I do have a voltage meter- will let y'all know what I find, thx!
  4. NWidder
    NWidder Member
    Oct 14, 2014
    166
    24
    Appleton, WI
    03 Vegas, 14 Cross Country
    I would also check the 40a breaker or just replace it.
  5. md2420
    md2420 Well-Known Member
    May 10, 2016
    2,758
    1,229
    Chandler, AZ
    2014 Vision
    in his first post he said he changed the 40 amp breaker last year. But yes, good to check it as well as it’s a crucial part of the system. Hopefully it didn’t fail in just 12 months of use.
  6. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    5,722
    2,416
    Littlestown
    Alex, I'd like loose battery cables for $500.
    • Funny Funny x 2
  7. lou8700
    lou8700 Well-Known Member
    Dec 3, 2012
    6,107
    3,144
    St. Louis
    Many of the replacements aren't as waterproof as the original and need to be sealed.
  8. md2420
    May 10, 2016
    2,758
    1,229
    Chandler, AZ
    2014 Vision
    agreed. Hopefully he saw the many posts (and Paul’s video) on sealing and replacing properly.
  9. Wild Bill
    Dec 17, 2019
    192
    96
    Cross Roads
    Ok, just pulled the chin fairing off, tested it and it showed 12.77, jiggled a few connections and she fired up. I just rode her home, will test it while on and tighten up all the stuff in there. Lost 2 of the bolts that hold the plastic thing in....gotta find some plastic lock washers. Thx all for the input, I'll check back when I finish up!
    • Winner Winner x 1
  10. Pauljp
    Nov 28, 2013
    1,283
    818
    Quebec Canada
    12.77 seems a good voltage for a resting battery so I think it is fine.
    Check for corrosion as well while you are inspecting the cables.
    Perhaps a bit of dielectric grease on the connections will be a good preventative measure as well.
    Keep us posted.
  11. 1stVictory
    1stVictory Well-Known Member
    Feb 14, 2012
    6,527
    1,685
    Edmonton, AB
    2012 Pearl White CC Tour
    A battery can show a bright headlight but no amps to start the bike. Your battery may be duff regardless of its age. Consider a new one, at least you'll know it's good.
  12. MacDony
    MacDony Active Member
    Jan 21, 2015
    189
    239
    France - Ambillou-Château
  13. 53canuck
    53canuck Well-Known Member
    May 25, 2013
    1,977
    826
    Left Coast, Canada
    2011 KP
    Per your initial description the lights came on so you had some power. While the 12.6volts or above is a good indication of the condition of the battery the voltage on a battery at rest isn't telling you the whole story. Especially if you take the measurement within a couple of hours of a charging cycle whether it be from riding or on a battery charger. What you need to do is see what the voltage drops to while you're trying to start the bike. That's when the problem hits. If it drops below approx 9.4v then the power is too low. As an example, mine doesn't go below 10.6v.
    Basics. As already mentioned, the connections are first thing to check. Vibration, exposure to the elements and short trips don't play well with the connections. Make sure everything, power and ground, is clean and tight. If you find the starting voltage drops too far below the 9.5v put the battery on a charger. Not one of the maintainers - a proper charger. Let it fully charge over night. Then after an hour or so after the charger has been removed go through the voltage measurements at the battery in the bike. 12.6v stopped, 9.5+v starting, 14.2v idling, 14.2ish (after a slight bump) rev'd to 2000. If starting voltage still drops too low then it's a best bet the battery is the problem but it's not certain. Yet.
    What you described can also be caused by heat soak although you indicated you were stopped for a few hours which seems a bit long for that. Batteries don't like extreme cold or heat and the available power drops in both instances. When you park the bike and stop the airflow, the heat off of the engine continues to radiate and heat up the battery higher than when riding. A weak battery will weaken further and labour under the load of trying to start the bike. As it gets back to normal operating conditions it can recover and will seem fine. If that's the case the battery needs attention.
    It certainly doesn't sound like something major but you need to go through the checks and testing we've mentioned or you may find yourself stranded again in a less convenient location.
    Good luck and let us know what you find.
  14. Wild Bill
    Dec 17, 2019
    192
    96
    Cross Roads
    Well, looks like it was just a loose connection somewhere. I tightened everything on the battery and those behind it and all is well. For whatever reason the bolts on the plastic fairing are working loose...just have to tighten them every once in a while I guess!?
    Thx again for all the help, it's always appreciated!
    • Like Like x 4
    • Winner Winner x 1
  15. Smokier104
    Smokier104 Active Member
    Nov 4, 2018
    250
    198
    Eastern Iowa
    '14 Cross County Tour
    Winner Winner, chicken dinner for you!
