I keep them in stock if needed.OK, I tried to get a Yuasa but they were backordered- got a generic battery with hi output.
How do you test for the amp draw?
That tends to happen, use star washers to slow it down so only have to retighten every other oil changeI'm thinking it's just the cables getting loose after a few thousand miles or so.
Make sure those connections are tight as well as the ground from the battery to the bike.I got a new battery in the summer, ride quite a bit so rarely put on a tender- when I do it shows that the battery is full. Today it did nothing, no clicks or anything and the tender shows it's full- any ideas?? I put lock washers on the terminal bolts.
Speed Test
Thx in advance!
