Now referred to as an "Obama solution"...pa06jackpot said:My dealer told me to shave the inside of the cover down. I love their "rig" jobs.
My Pleasure!mpt5656 said:Andy, thanks for posting the pics. I couldn't figure out for the life of me how to post them.
Thats funny!stilcrazee said:Now referred to as an "Obama solution"...pa06jackpot said:My dealer told me to shave the inside of the cover down. I love their "rig" jobs.
I have an 08 Vegas Low. I have the same problem. The belt has been adjusted numerous times. No help. It drives me nuts!OneThumb said:I believe that problem has been corrected. they redesigned the cover. In 07 or 08 the change was made.
OT
Have you had your cover off to see if the beltis actually rubbing it? There are some issues with the rear pulley that causes chirps too.rocketman37 said:I have an 08 Vegas Low. I have the same problem. The belt has been adjusted numerous times. No help. It drives me nuts!OneThumb said:I believe that problem has been corrected. they redesigned the cover. In 07 or 08 the change was made.
OT
That's my next step. Can you take the cover off without taking the pipes off?OneThumb said:Have you had your cover off to see if the beltis actually rubbing it? There are some issues with the rear pulley that causes chirps too.rocketman37 said:I have an 08 Vegas Low. I have the same problem. The belt has been adjusted numerous times. No help. It drives me nuts!OneThumb said:I believe that problem has been corrected. they redesigned the cover. In 07 or 08 the change was made.
OT
OT
Sorry, That's one I can't answer, contact the author of this thread, it looks like he's been there, done that. LOLrocketman37 said:That's my next step. Can you take the cover off without taking the pipes off?OneThumb said:Have you had your cover off to see if the beltis actually rubbing it? There are some issues with the rear pulley that causes chirps too.rocketman37 said:I have an 08 Vegas Low. I have the same problem. The belt has been adjusted numerous times. No help. It drives me nuts!OneThumb said:I believe that problem has been corrected. they redesigned the cover. In 07 or 08 the change was made.
OT
OT
Did you have to take the pipes off to remove the cover?mpt5656 said:I have posted information about the squeel/whine/chirp that I am getting from my 2006 victory vegas. To start off with a little history, when I purchased my motorcycle I got it lowered by using a rear shock from a victory vegas low. This was suppose to be better than the lowering links that you can buy. When I hit a bump or have a passenger I notice the belt making noises, which my dealer said was from the belt being too tight. I had them adjust the belt and that did not help, in fact it made the belt bang up against the belt guard ever once in a while. After further inspection I found out that the drive belt cover was the problem. The belt was so close to the first bolt boss that when the shock depressed it created the noise, which was the belt rubbing. I removed the cover and took pictures to show everyone. because the pics are too large I placed them in the gallery under belt cover, there should be a total of 5 of them. The first one you can see where it is rubbing. The other ones are from when I removed it and took pictures of the build up of rubber on the boss and the missing chrome that wore down. You can also see rubber particles on the inside of the cover. I hope this helps some people that have the same problem I have![]()
