1 - 18 of 18 Posts
Is it necessary to install new bushings when installing a Ness brake and shift lever or do they already have them on the Ness shifter and brake arm? I know the stock arms need the bushings. Just curious want to do install but dont want to have to stop for bushings If I need them I will get them before install. thanks
I think I would call the vendor and ask them to check. I replaced mine with some Whitewall Chopper something or others- NOT RECOMMENDED by the way. They are off my bike now.
I had instructions that led me to believe that I would need to reuse the stock lever bushings, but they came with their own.. Obviously that does not mean the Ness brand will. In the end- any reason why you could not use the OEM ones if you had to?
@edword Just use the stock bushings the ness one's don't come with bushings. smear some grease in the bushings too.
1 - 18 of 18 Posts
