Saddle bag lights | Victory Motorcycles: Motorcycle Forums
Saddle bag lights
Discussion in 'Victory General Discussion' started by ledzep, Jun 22, 2020.
  1. ledzep
    ledzep Active Member
    Feb 4, 2014
    308
    46
    Masachusetts
    2011 cross roads, victory fairing, 2" pullback bars, Lloyds drop in cams, timing wheel, IAC idle valve, lloyds exhuast gaskets, D and D pipes, 1/4 turn throttle ring, Barnette push and pull stainless throttle cables, PCV tuned by Klye KMC 120hp, 118 ft lb
    What are guys using for saddlebag inside lighting? Want to add led's inside bags. Also were are you tapping into?
  2. ledzep
    Feb 4, 2014
    308
    46
    Masachusetts
    2011 cross roads
  3. PDXLaserGazer
    Jun 3, 2013
    3,782
    1,248
    Molalla, OR
    I carry a flashlight, but instead of hardwiring, you could pick up some small cheap stick-on LED lights, more expensive might have level switches if you want to put it on the lid so it shuts off when the lid is closed.
    But if you want to hardwire, could look into a shutoff switch that closes/opens with the lid is closed/opened and tap into the auxiliary power connectors under the rear fender on the right (brake) side if it's using the same harness as the XC/T, might be taped up. Will be 2 female spade connectors if I remember right.
  4. ledzep
    Feb 4, 2014
    308
    46
    Masachusetts
    Thanks for reply, are any particular brands that have been used that are bright and reliable that u all run?
  5. Wardogg
    Wardogg Member
    Jul 10, 2014
    83
    42
    Tucson Az
    2013 Victory Jackpot
    • Like Like x 3
  6. VicVisionBulldog
    Mar 27, 2011
    19,012
    11,786
    Houston
    I stuck these in my bags. Stuck them inside on the most forward wall shining back into the bag. They have been pretty good and have stayed in place. Real cheap. One did have an issue with a terminal on one batter on one light. Only needing 4 I didn't worry about it and just threw it in the drawer for possible spare parts later..
    5 Pack IPOW LED Battery-powered Wireless Night Light Stick Tap Touch Lamp Stick-on Push Light for Closets, Cabinets, Counters, or Utility Rooms, Cordless Touch Light, Batteris Not Included - - Amazon.com
  7. VicVisionBulldog
    Mar 27, 2011
    19,012
    11,786
    Houston
    I put a set of these in the back of my Jeep. Having magnets I simple stuck them to the side of a Tuffy security box but they do come with a disc to stick on nonmetallic items. They are more extensive but are MUCH better quality. One on each side lights up the entire box area really well so usually I only turn one on and it's plenty of light. I took the third to work for my locker.
    https://www.amazon.com/dp/B074C8HCF7/ref=cm_sw_r_cp_apa_i_tnh-EbN2H52R9
  8. MagVic CCT
    MagVic CCT Well-Known Member
    Dec 26, 2014
    8,416
    3,942
    Right here.
    2000 Nomad : 2012 Victory CCT
    I got a set of those that came with remote control on/off and dim. We use them as background lighting above the kitchen cabinets to display items placed there. But they are very useful just about anywhere you want to put them. Say, like in the back of a Jeep.
  9. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    9,757
    3,803
    South Florida
    2011 Cross Country
    Battery operated leds are fine. Less hassle and they last. They are not on long anyway. Why hardwire.
    Check out : Superbrightled.com
    They have everything LED.
  10. VicVisionBulldog
    Mar 27, 2011
    19,012
    11,786
    Houston
    Those in the Jeep are good because being a magnet I can take them and move them wherever I please. Work light, beach lights, whatever.
  11. IndyVictory
    IndyVictory Member
    May 29, 2020
    75
    27
    Indianapolis
    My bike came with mercury switch operated lights in trunk and sides of trunk that light up the saddlebags. I can't complain it's perfect. Prior owner did that and while the wiring doesn't look the best it works so not messing with it.
    For a cross roads I'd go with something simple like those cheap battery LED lights harbor freight sells. Just velcro it to the lid so you can grab it when you need it.
  12. ledzep
    Feb 4, 2014
    308
    46
    Masachusetts
    Great suggestions, thanks guys!
  13. roadcouch
    roadcouch Well-Known Member
    Jan 1, 2013
    3,170
    5,388
    West of chicago
    2013 xc sunset red
    I use my flashlight on my cellphone. Simple
    • Funny Funny x 1
  14. slickvic
    Dec 22, 2011
    9,757
    3,803
    South Florida
    2011 Cross Country
    I just don’t open them at night.
    • Funny Funny x 1
  15. MagVic CCT
    Dec 26, 2014
    8,416
    3,942
    Right here.
    Yeah, but what if you have to get to your leather pajamas and your batteries, and the cute little toy, that.........uh, nevermind.
