Me too! I understand the Smith's map is the best.
If I install the intake - will the bike run well enough to get it to shop to have it mapped [this is my first injector - carbs were easy].
Depends on how far you are from the dealer and if your pipes have full heat shields.SofaKingBlue said:Me too! I understand the Smith's map is the best.
You will be running lean and if you dont have heat shields the pipes start blueing real quick. I found that out the hard way with my Ness pipes.Sutherland said:Question
What has heat sheilds got to do with it, weather they and full or not
Regards
I GOT THE AMS FROM HACKER PIPES ITS PLUG AND PLAY AND YOU CAN ADJUST IT TO SUIT YOUR NEEDS IT WORKS FINE FOR ME GOT MORE POWER BETTER ROLL ON SPEEDS NO JERKIN AT LOW REVS AWSOMEdsjr70 said:Depends on how far you are from the dealer and if your pipes have full heat shields.SofaKingBlue said:Me too! I understand the Smith's map is the best.
Post a picture if you can. I'd really be interested in knowing how it looks sitting on the side of the bike. I know the performance upgrade will be spot on as long as one adds pipes too. Thankslloydtuk said:i fitted it to my jackpot its an awsome bit of kit but its a bastard to fit you have to cut the standard air box out as it is fitted in the frame before the engine goes in.
but its worth the greif
A pic really isnt going to help you. The great thing is you dont see it so that big cylinder shines!MtnRider said:Post a picture if you can. I'd really be interested in knowing how it looks sitting on the side of the bike. I know the performance upgrade will be spot on as long as one adds pipes too. Thankslloydtuk said:i fitted it to my jackpot its an awsome bit of kit but its a bastard to fit you have to cut the standard air box out as it is fitted in the frame before the engine goes in.
Yeah, now I see (or don't see) what I was looking for. I was concerned it was going to hang off the side of the bike stealing attention away from the beauty of my lines.dsjr70 said:A pic really isnt going to help you. The great thing is you dont see it so that big cylinder shines!MtnRider said:Post a picture if you can. I'd really be interested in knowing how it looks sitting on the side of the bike. I know the performance upgrade will be spot on as long as one adds pipes too. Thankslloydtuk said:i fitted it to my jackpot its an awsome bit of kit but its a bastard to fit you have to cut the standard air box out as it is fitted in the frame before the engine goes in.
MtnRider said:Yeah, now I see (or don't see) what I was looking for. I was concerned it was going to hang off the side of the bike stealing attention away from the beauty of my lines.dsjr70 said:A pic really isnt going to help you. The great thing is you dont see it so that big cylinder shines!MtnRider said:Post a picture if you can. I'd really be interested in knowing how it looks sitting on the side of the bike. I know the performance upgrade will be spot on as long as one adds pipes too. Thankslloydtuk said:i fitted it to my jackpot its an awsome bit of kit but its a bastard to fit you have to cut the standard air box out as it is fitted in the frame before the engine goes in.
I found some good pics of one installed on a kingpin thath7wae14t has in his gallery. Hope it helps others too, check out his pictures, beautiful KP too.
sorry mine fits under the fuel tank not on the side
