RPM's rise and bike hard to start when Hot | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory General Discussion' started by VictoryBreezer, Jun 1, 2018.
  1. VictoryBreezer
    VictoryBreezer New Member
    Sep 15, 2017
    12
    2
    2009 Victory Vision
    Hey Guys. This has happened twice now. When stuck in stop/go summer traffic my Visions engine RPMs rise and stays around 1500-1600 RPM's and the RPM's surge. Victory First time this happened last summer I turned the bike off several times and barely got it started again. When it happened again this week I did not turn my bike off to avoid the starting issue. Bike seems unhappy when this happens. Not a battery issue. Still using the same battery I was using last year. Works fine ever other time. Even after moving again the bikes RPM's stay high and only seems to get better after been put away for the night. Where should I start? Vacuum line?...Throttle body?...plugs?... I am planning on doing a full tune-up soon (throttle body cleaning, oil, plugs, air filter, etc).
  2. vision_nut
    Aug 15, 2011
    7,876
    746
    vision 08
    no throttle body to clean. Add plug wires to your list.
    So just how old is battery 3 or 5 years old.
    Get a hold of Rylan he can tell you more then us guessers
    Contact - The Vic Shop
  3. Dan050
    Dan050 Well-Known Member
    Jun 8, 2012
    579
    333
    NE Indiana
    Cross Country Tour
    I got stuck in some very hot stop and go traffic on vacation once. Finally was able to exit to take a much needed break. When we were ready to take off, bike would turn over strong but not start.
    Eventually it started and all ok.
    After inquiring about it on here, it was brought up that a few have experienced what acts like a vapor lock condition.
    I don't recall having the RPM issue you had tho.
  4. VicVisionBulldog
    Top Poster Of Month
    Mar 27, 2011
    21,326
    9,519
    Houston
    What kind of temps are we talking about?
  5. primethious
    primethious Well-Known Member
    Aug 14, 2013
    7,993
    2,436
    2012 Victory Cross Roads
    RPM surging could be a vacuum leak.
  6. Trout
    Trout Well-Known Member
    Nov 21, 2015
    2,335
    1,231
    G'ville FL
    2013 XCT, 1989 Guzzi Mille GT, 2001 Guzzi Jackal, 2013 Guzzi Griso
    Loose batt connections / bad batt can also cause the RPM surge.
    Really need to put a wrench on the batt terminals NOT just wiggle with fingers.
  7. BoilerMan
    BoilerMan Well-Known Member
    Mar 20, 2014
    2,497
    1,048
    Sesser IL
    2020 Harley FLHCS 114.
    Agree with @Trout . Also get your battery load tested and if you need to just replace it, heat can really screw with a battery that is not 100%.
  8. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    11,307
    4,772
    South Florida
    2011 Cross Country
    Me Breezer. Welcome.
    Have you done any modifications to your bike ? Is it stock. Let us know so we can help better. You can put it in your signature.
    If you don’t have a fuel tuner and you ride in stop and go a lot in a warm climate then I would get one. Even a stock motorcycle will benefit from a tune with a PCV or another popular tuner. Dyno tune is a good idea when installing a PCV.
    I’m not suggesting you hot rod the bike although cams, exhaust and free breathing intake certainly add to the experience of a great running Victory. I’m suggesting the fuel tuner to simply run the motor cooler and get it away from that dreaded stock / EPA lean tune that so many still complain about. The fix is easy. The benefits are long lasting.
  9. FoFo
    FoFo Well-Known Member
    Jun 14, 2016
    1,772
    997
    Fort Worth, TX
    2010 Victory Cross Roads
    As a number have said above, check the battery. It amazes me how many good batteries have been bad.
    But you can test for vacuum leak around the boots by spraying wd40 around them at idle. If the RPM's change you have a leak. There are tons of videos on how to check this.
    Let us know what you find.
  10. VictoryBreezer
    Sep 15, 2017
    12
    2
    2009 Victory Vision
    Thanks for the great responses guys. I have had the bike for two year and was told by the original owner the battery was about a year old, so 3 year old battery if told correctly. I will check these terminals better and will check the battery load. There has been no modifications to the bike except the upgrade Victory Exhaust system (stage 1 i guess?) This has only happened twice, but got me paranoid when I get into traffic. Took the bike out today in 95 degree Florida weather with moderate stop go traffic and no issues. This has only happened when traffic is a crawl for an extended time. I'm not running a temp gauge so no idea what the bike temp is getting up to, by no warning or indicator lights are coming on. The bike has 9,000 miles if this helps. Will has plug wires to my tune-up and will check the vacuum lines with conducting the tune-up. Thanks again. Great tips!
  11. Trout
    Nov 21, 2015
    2,335
    1,231
    G'ville FL
    Where you at in FL?
    I'm in Gainesville.
  12. VictoryBreezer
    Sep 15, 2017
    12
    2
    2009 Victory Vision
    The panhandle....Navarre
  13. Trout
    Nov 21, 2015
    2,335
    1,231
    G'ville FL
    One of my favorite camp spots is just North of you in Alabama.
    You're about 5 to 6 hours from me.
  14. vision_nut
    Aug 15, 2011
    7,876
    746
    vision 08
    VictoryBreezer
    now that we know where you live. The top tuner in the southern part of the country is Kevinx. He can do more for you then any of us hear. Hes fair priced and honest.
    17708 High Springsw Main St
    High Springs, Florida
    [​IMG]
    @kevinxsouthernmotorworx
    [​IMG]
    Call (352) 215-3253
  15. VictoryBreezer
    Sep 15, 2017
    12
    2
    2009 Victory Vision
    Thank You!
