Rotella | Page 2 | Victory Motorcycles: Motorcycle Forums
Rotella
Discussion in 'Victory Judge' started by inkedrider, Mar 16, 2021.
  1. Trout
    Trout Well-Known Member
    Nov 21, 2015
    2,335
    1,231
    G'ville FL
    2013 XCT, 1989 Guzzi Mille GT, 2001 Guzzi Jackal, 2013 Guzzi Griso
    OK OK Mea Culpa!
    After rethinking the hi mileage castrol I dumped it at 3k miles and now have Rotella T6.
    I was not considering the fact that the engine oil is also the gear box lube & those Vic Straight cut gears would be very hard on the oil.
    Thanks slickvic
  2. bikendad
    bikendad Well-Known Member
    Apr 10, 2009
    6,925
    1,208
    SE Michigan
    2010 Victory Cross Country
    Close but the T5 is the correct one to use.
  3. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    11,226
    4,717
    South Florida
    2011 Cross Country
    He’s getting there.
    • Funny Funny x 1
  4. Bikesofbrads
    May 16, 2020
    1,801
    997
    South eastern ohio
    2015 victory xct & 06 katana
    I’m still a lil mindfuked that most synthetic blended oil only contains about 10% synthetic oil within it. The old ass-u-me saying comes to mind. Instead of my 50/50 mix am gonna go to the 3 to 1.25 ratio next change just for giggles to C if can tell any difference. Gotta admit the bike shifts really nice mixing 50/50
  5. Chattanooga_Mark
    Dec 25, 2009
    4,668
    1,928
    Chattanooga
    2012 CCT, Wonderful in white
    Rotella T6 works perfectly, has the correct JASO MA/JASO MA 2 rating and is a full synthetic. No problem whatsoever using Shell Rotella T6 in our Victorys.
    Yes, it was designed for diesel engines and also yes, it's perfectly suited for our wet clutch motorcycles. Many manufacturers products are suited to perform more than one function.
    Having the JASO MA /JASO MA 2 rating is the key. That means the oil is suited for our wet clutch motorcycles.
    If paying over $10 per quart for 15W-40 'motorcycle specific' oil suits you, fantastic. That's an expensive label on that quart, no wonder you're pleased with your purchase.
    If paying $20 for a gallon of 15W-40 Shell Rotella T6 at Walmart suits you, congratulations, you passed the test.
    • Winner Winner x 7
  6. bikendad
    Apr 10, 2009
    6,925
    1,208
    SE Michigan
    The spec calls for semi-synthetic, some get clutch slippage with full-synthetic. The T5 is a blend of T4 and T6 which are both JASO MA rated and tested. Shell reps have come out and said T5 will pass the testing but they are unwilling to pay for it to satisfy a niche market. My clutch grabs better with T5 than it does with the Vic oil.
    • Like Like x 3
  7. slickvic
    Dec 22, 2011
    11,226
    4,717
    South Florida
    2011 Cross Country
    Yes this ..... and it’s true but I can’t say my clutch grabs better with T5 because I don’t use it. But Spectro 20/40 semi synthetic ?????? Oh yeah that oil grabs.
  8. TommyGunn
    TommyGunn Active Member
    Feb 28, 2018
    141
    69
    Lewis County, Washington
    Vision
    Rotella 15-40 T6 for all my bikes. Never a engine failure, never a clutch slip. 38k on the Vic, 32k on the Tenere, 40k on the Buell. Change them all at 3k unless I’m on a road trip then I’ve gone 5-6k.
    • Winner Winner x 1
  9. Trout
    Nov 21, 2015
    2,335
    1,231
    G'ville FL
    I e got about 2k on the t6 no clutch slippage n engine is quiet. Going to start using it in all the Guzzis also which are dry clutches.
  10. notaharley
    notaharley Well-Known Member
    Oct 1, 2012
    4,170
    1,816
    Effingham, NH
    VISION, BABY!
    I have run T6 for way over 100,000 miles in 3 Victorys.
    Excellent oil.
    My Indians call for a higher viscosity, so I haven't used it in them.
  11. slickvic
    Dec 22, 2011
    11,226
    4,717
    South Florida
    2011 Cross Country
    Just when you thought I wasn’t going to respond to the Rotella crowd. So let’s look at especially the T5 which has a robust package of additives. Notice the moly content compared to the others ? Hmmmm ....
    Then look at the Boron count. Not sure what this means to a motorcycle with a wet clutch but there is a distinct difference between the chosen 2 Rotellas that are widely used here. 15/40 T6 full syn and 15/40 T5 semi syn. Just something to help you make a choice although I’m not sure which is the better for your Victory oil since the additive package is different.
    • Informative Informative x 2
  12. IM12STPN
    IM12STPN Well-Known Member
    Nov 1, 2014
    12,322
    7,140
    Houghton Lake, MI
    2016 Vegas 8-Ball BLACK!! 2016 CCT...BLACK also
    @slickvic need some of that OIL on your keys..............................................................................:crackup:
    • Funny Funny x 3
  13. TommyGunn
    Feb 28, 2018
    141
    69
    Vision
    Molybdenum Disulfide is a friction modifier. It’s a graphite filler material that bonds with surfaces to make a hard wear coating. Ever get powdered graphite on your fingers and try to get it off? It fills in all the microscopic pores in the steel and your clutch.
    Probably why it’s not JASO rated.
    Back in the late 70’s and early 80’s ARCO came out with a engine oil labeled as Graphite and it had a very high Moly content. A friend of mine bought a new Yamaha XS11 in 1982 and took a road trip to Montana a few months later. He changed his oil with the ARCO high Moly and ended up riding back from Montana in only 3rd and 4th gears because the clutch slipped so bad.
  14. TommyGunn
    Feb 28, 2018
    141
    69
    Vision
  15. Dan050
    Dan050 Well-Known Member
    Jun 8, 2012
    575
    332
    NE Indiana
    Cross Country Tour
    That's very interesting. That kind of blows the theory that t5 would be the same as mixing the other 2 together.
    • Agree Agree x 3
