Right turn signal only.
1 reading
2.4K views 3 replies 2 participants last post by  808XCOUNTRY
#1 ·
I just installed 1 of those l_e_d strip running board turn signalights. everything works great until I start riding the bike. Only the right turn won't work. I checked all the continuity on the ground everything working, like I said when not riding, left /right and hazard. I read the manual and it said it recieve a ground signal so I'll try to re splice the ground on the right turn side. Left turn signal is all good and working. Anyone experience this?
Thanks
#2 ·
Update, so after checking all connection it was still not working on the right turn signal, so I started thinking just maybe its drawing g a little to much amps. So I cut back the light strip and it now works perfect. I hooked it up by tapping into the turn signal wires in the fairing same as how WD did.
My question is if I wanted to add. More led turn lights in the back like those sabre tooth led on the saddle bag, how do I wire those up if with just the floor board light its overloading turn signal system? Thanks
#3 ·
Well, if you want to add lights to your heart's content, and those lights are to function as turn signals, and you've encountered a limit when using the stock turn-signal wires, you can always add a trailer isolator.
I added an isolator when I put in Rivco's mirrors with LEDs on them -- they have running and turn-signal lights facing forward, and turn-signal lights facing rearward -- and everything works as intended. The bad news is that this gets expensive, and is a bit of a pain in the ass to wire up.
If you're still interested in this solution, I have a verrrrry looooong write-up on this whole project as a page on my web site, with pics and instructions, here:
Adding Rivco LED Mirrors to a Victory Cross Country Motorcycle
(And the good news is that you can skip large chunks of that write-up, and not miss much.)
