Reverse motor kit | Page 4 | Victory Motorcycles: Motorcycle Forums
Reverse motor kit
Discussion in 'Victory Vision' started by DIANJOR1, May 15, 2012.
  1. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    5,203
    2,174
    Littlestown
    Email sent
  2. Tru_111
    Tru_111 Member
    Feb 25, 2021
    77
    96
    Moscow, Russia
    Victory Vision Tour
    Got it all. Thank you, this is what you need!))
  3. Buellee
    Buellee New Member
    Sep 23, 2018
    9
    kc
    2011 Victory Vision trike
    Mark does tell
  4. Buellee
    Buellee New Member
    Sep 23, 2018
    9
    kc
    Mark does your information tell you hove to install it or remove it . I need to remove mine there is something broken and grinding..
    Thanks
    Tom
  5. Chattanooga_Mark
    Dec 25, 2009
    4,991
    2,124
    Chattanooga
    2012 CCT, Wonderful in white
    I have the installation instructions which when read back to front also serve as removal instructions. Is the gear that moves over into the front pulley not going all the way over and is that what’s grinding? I can certainly email you the pdf if needed.
    I hope you can find the cause and a cure. Sadly, some of the individual parts are NLA.
  6. Geobob
    Geobob Active Member
    Oct 3, 2017
    212
    65
    Williamsport, Pa
    88 Yamaha Venture, 07 Vstar 1300, 13 GSXR 750, 82 Honda CBX, 79 Turbocharge EFI CBX
    I have had to replace the key on the shaft at least once. I believe it is designed the shear if you do something like pop it into first when you are drunk. Otherwise it is pretty simple. Just adjust the action rod to some place between too far and not far enough and it will work. There is a kill switch in there that I believe is supposed to shut the motor off if you engage the gear at the wrong time. I have replaced my under drive pulley so I’ve been in there at least two or three times now. As far as the wiring goes it could be as simple as a plug and play with the harness might already be set up just to plug the thing in but I’m not sure about that. As far as the hardware goes it’s just the sprocket on the end on the pulley and a little motor in the mechanism to move engagement gear in and out. Something does tellThe electricity to stop going to the starter motor and start going to the reverse motor when you put it in gear or engage it but other than that I’m not sure what else the wiring system looks like for the kit
  7. Geobob
    Oct 3, 2017
    212
    65
    Williamsport, Pa
    One thing I didn’t notice was that you need to take the exhaust system off to get the outside cover off if you really need to investigate the drive . My shop manual discusses the reverse system in pretty good detail
  8. Buellee
    Buellee New Member
    Sep 23, 2018
    9
    kc
  9. Buellee
    Buellee New Member
    Sep 23, 2018
    9
    kc
    I removed the screws from the gear cover and heard a clank. I moved the trike forward and back. A piece of the bracket that holds the idler and pinion gear fell out and one screw closest to the wheel goes into that piece. I need to find the circuit that is attached to the limit switch to jumper so i can start the trike. It does look like I will have to remove the exhaust system. That scares me because the bolts are rusted and may break
  10. Bikesofbrads
    May 16, 2020
    2,200
    1,266
    South central/eastern ohio
    2015 victory xct & 06 katana
    Liberal amounts of penetrating spray after cleaning rust off threads with a brush, allow overnight time to soak in & may hafta use a small propane torch to heat up threads so will come loose. Have patients & you’ll get it.
2005 yamaha royalstar reverse
2009 yamaha royal star venture pro and cons
convert a victory vision reverse kit to a king pin
has anyone found a faster reverse for victory motorcycle
how does victory vision reverse work
hw does reverse work opn a motorcycle
reverse on victory vision
reverse transmission for victory motorcycle
reverse victory sign
victory motorcycles reverse kit
which victory motorcycle has reverse
