1 - 3 of 3 Posts
Hi all,
The rear running light on my XC has stopped working. The brake light works ok. I also have no blinkers. There was a 10amp fuse blown which I think happened when I changed the bikes battery. Could it be a relay problem?
Thanks for any pointers
I would check your fuses first. They are designed to protect the relay by breaking the current if it is too much for the circuit.
You correct mate. That's the first thing I did. It had blown the 10 amp fuse.
It was once the fuse was replaced I noticed the back light was out.
So, i replaced the two relays. This restored the the back lights and in some respects the blinkers. However they just come on and stay on in random ways every time the ignition is switched on.
The new flash module turned up this afternoon but work stopped play.
I'll report back on e its installed.
1 - 3 of 3 Posts
