Rear cylinder no spark cross country | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory General Discussion' started by Nomad1776, Mar 19, 2020.
  1. Nomad1776
    Nomad1776 New Member
    Mar 19, 2020
    4
    2014 Victory Cross Country Tour
    Hey everyone,
    First post and its a big one. Ive been running a 2014 victory cross country. to date ive done a PC5, timing wheel, dino, lloydz cams and v&h slipons. recently i had my mechanic wire in a victory oem tour pack. the connectors on the tourpack didnt line up on the bike side quick connect so he had to pull pins and do a aftermarket connector. also had ape hangers installed at tha time as well. low and behold the rear cylinder has stopped firing. it gets fuel but no spark. front cylinder is fine. Me and my mechanic are running out of options...looking for some advice. i have suggested removing the pc5 to see how it runs. or getting a new ecm. Any suggestions would be helpful. Victorys are amazing bikes. i have taken mine all across the eastern seaboard and wouldnt trade it for any other. Please post anything you thinkmay be of value. Cheers
  2. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    11,086
    4,650
    South Florida
    2011 Cross Country
    Re trace your steps. Check the FI connector at the top of the rear cylinder. Spark plug wire ? look at the coil connection ? Doubtful you need a new PC5.
  3. Nomad1776
    Mar 19, 2020
    4
    Thank you, my buddy thinks we may have back charged one of the pins on the quick connector when we were testing to figure out which pin did what? does anyone know what pins are in that harnes for the trunk that comes off the left side in fron of the left saddle bag? I will try the suggested items though thank you
  4. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    4,688
    1,915
    Littlestown
    PC-V ground and check all grounds.
  5. Nomad1776
    Mar 19, 2020
    4
    All good ideas, Does anyone know how to test the coil?
  6. WeekendRider
    WeekendRider Active Member
    Nov 17, 2015
    214
    90
    Illinois
    2013 Cross Country
    @BBob maintains a site with the service manuals. You'll find everything you need there. The link is in his signature but for simplicity here you go:
    MediaFire
  7. 1stVictory
    1stVictory Well-Known Member
    Feb 14, 2012
    6,253
    1,534
    Edmonton, AB
    2012 Pearl White CC Tour
    And the "mechanic" shrugged his shoulders and went home? Strike him from even washing the bike. How wiring a high mount brake lamp and speakers can kill spark to the rear cylinder is a head scratcher. I wish you well.
  8. Bomb461
    Bomb461 Active Member
    Apr 21, 2016
    326
    172
    SW Michigan
    '14 XC, '95 FLHT
    How did this turn out? My 14 XC, very similar extras set up, just up and did same. Nothing added, nor new...tho since I have tried PLUGS, WIRES AND COIL! WOULD LOVE ANY INSIGHT!
    Bomber
  9. 1stVictory
    Feb 14, 2012
    6,253
    1,534
    Edmonton, AB
    Spectro Golden 20W-40?
  10. Nomad1776
    Mar 19, 2020
    4
    Ended up replacing the pc5. That did. It you can also test the pc5 by disconnecting the power to it and replugging in the stock ignition coil wires. Hope this helps
  11. Known1
    Known1 Well-Known Member
    Apr 30, 2012
    4,464
    1,474
    Cement Slab, MN
    2013 Cross Country Tour
    I'm surprised you didn't dump the PC-V and go with a Maximus tune. It truly is a better all around tune and you don't have approximately 12 new electrical points of failure wired in to your bike.
  12. CrazyDiavelRider
    CrazyDiavelRider Active Member
    May 19, 2020
    123
    100
    Houston TX
    Victory Vision tour 2014
    No reason to dump a pcv it's a very good working unit. It is rare they go bad.,
  13. slickvic
    Dec 22, 2011
    11,086
    4,650
    South Florida
    2011 Cross Country
    Just curious. You replaced the PC5 and problem solved. Who help you with a canned tune and a new unit ? Info like this will helpful if it happens to someone else.
  14. Known1
    Apr 30, 2012
    4,464
    1,474
    Cement Slab, MN
    I'm going to have to disagree. It's simply a matter of time before it will give you issues. It took mine about 70,000 miles and 4.5 years.
  15. CrazyDiavelRider
    May 19, 2020
    123
    100
    Houston TX
    I
    13 bikes in my lifetime.10 had a power commander of some type. Never an issue.
    3 Victory's again not an issue. It's the very rare issue that's makes it seem that the sky is falling .
