On mine, if the kill switch is in off, the amp doesn't get power.I tried the mute, amp is only front the current from speakers turns on amp, rear speakers are directly from radio. I was hoping someone has seen this issue. Display is fine but no sound. Radio set to 88. 9 FM
Local motorcycle shop says 220+ 90 labor found one on eBay . I'll hope for the Best. P/N matched .The radio on the Vision is made by N Touch. If it comes down to it you can send it to them and they'll replace it for around $250. That said your bike may still be under warranty and the dealer can send it in for you.
I had the opposite happen with my screen going out but it still played music. My extended warranty covered sending it in and getting it replaced. My dealer was nice enough to let me keep the bike while it was out and then stop by to let them install it again when it returned. Took less than two weeks. It's a 15 minute job if you're slow.
This thread may give you more insight about it just so you know a bit more about it.Local motorcycle shop says 220+ 90 labor found one on eBay . I'll hope for the Best. P/N matched .
@BigGirl if you go thru the radio menu you can check to if see the external speakers are set to off.
I believe you have to hold down the mode button to get into the radio menu. I believe that same button will let you toggle thru the options and the tune buttons adjust the parameters in the given setting.
I'm not afraid to take it apart I was just saying $90 is ridiculous but now I purchase a new radio and I plugged it up and I got nothing I took out the rear speakers put in the speakers and got Zero.This thread may give you more insight about it just so you know a bit more about it.
https://www.thevog.net/threads/p-n-for-09-vision-tour-radio.150141/#post-2979531
Do not be afraid of taking it out. Once you do it you'll see the $90 for labor is robbery.
I have Rockford Fosgate amp when the radio comes on the current from the speaker's activates the amp it's not power we not the rear has no amp and no sound. I'm 99. 9% sure that the speaker selector is on? I just received a new radio plugged it up no sound I attached the original speakers to the rear no soundOn mine, if the kill switch is in off, the amp doesn't get power.
The only other thing I could think of is maybe your trunk came unplugged somehow. Check to see if the taillights on the trunk still work. Then again your front speakers aren't working either. Correct?I have Rockford Fosgate amp when the radio comes on the current from the speaker's activates the amp it's not power we not the rear has no amp and no sound. I'm 99. 9% sure that the speaker selector is on? I just received a new radio plugged it up no sound I attached the original speakers to the rear no sound
I'ma check I hope the answer is out there somewhere. Your mouth to ghost ear , ear buds suck!The only other thing I could think of is maybe your trunk came unplugged somehow. Check to see if the taillights on the trunk still work. Then again your front speakers aren't working either. Correct?
The new radio still could have the external speakers set to off. It's worth the look and I've confirmed holding down the mode button gets you in there and the mode button toggles thru the options and the + - tune buttons adjust each option.
Maybe the Vision ghost will send me an email with other solutions for you.
