Unsolicited, and probably unwanted, but hey,,,,,
1. Add lower
deflectors, good for cold, great for heat, let them sit for 12 hours before use & trust the 3M tape. Good Luck on the wait. Look around on eBay.
2. Don't trust your kickstand, check it twice. No switch or positive down position, but it is designed to retract if you touch it down while in motion
3. Trust your tip over (TO) points, IF YOU HAVE THEM, use them, instead of a foot or ankle to catch a falling vision. GET your feet up quick when you move from a stop, TOs run on ankle blood.
4. Place a foot on your floorboard and jiggle the bike while gassing up, and take your time. It takes a bit to fill both tanks.
5. Replace your horn or get loud pipes, this thing is fast and nimble, but cagers attack it for no reason. Jealous or hypnotized, who knows, but they steer right toward you.
6. Don't ever take off the trunk unless you are OK storing it forever. Rides almost like a different bike without it.
7. Stay off your
front brakes below 5 mph, and pay attention in parking lots. The
fuel tanks are forward and low: great for the twisties, but takes some getting used to.
8. If you remove the trunk or drop test the TOs you are honor bound to tell us. It makes those of us who have tested them more than once feel better ( so I hear).
9. If you take any of the above advice and it turns out badly, blame yourself, I am not to be trusted.
10. Make sure you lube any mechanical control points routinely, but do not oil cables, it tears up the interior Teflon
11. Once you have leaned that thing as far as you think is safe in a sweeper, keep going if you haven't heard the floorboards scrape. It's lean angle is just ridiculous for a 900+ lb bike
12. Practice using our Forum Search feature. It works wells, saves tons of repetition, and avoids snarky-smart-Alec answers like I sometimes offer.
