Problem | Page 3 | Victory Motorcycles: Motorcycle Forums
Problem
Discussion in 'Victory Hammer' started by Schnudedungger, Apr 23, 2021.
  1. Schnudedungger
    Schnudedungger New Member
    Apr 23, 2021
    14
    6
    Hammer S
    thanks for the hint. i could get a 16er ecu and a 16er wiring harness. will probably have to bite into the sour apple and buy it☹️☹️
  2. Bikesofbrads
    May 16, 2020
    1,980
    1,123
    South central/eastern ohio
    2015 victory xct & 06 katana
    @Schnudedungger I’m not 100% sure if the 16+ ecu & harness is necessary but your problem may lie within that difference. I’d call a guru, Noe, Rylan, Lloyd or Conquest, I’d call them all just to ensure is a consensus on the issue
  3. 11ZNL
    11ZNL New Member
    Nov 22, 2020
    18
    5
    Edendale New Zealand
    V11 Sport Naked
    I do not think you need to replace the wiring harness. You need to find a wiring diagram and see how the side stand switch operates. European bikes have them and they are easily bypassed so yours should be similar. I looked up the wiring diagram for my Guzzi. When I put my stand down and the bike is in gear this closes a relay and activates the kill switch.
    The relay itself or the wiring could be faulty as your switch checked ok.
    Rob
  4. Schnudedungger
    Apr 23, 2021
    14
    6
    Hammer S
    Hello rob, thank you for the information. I'll show a person who can read my circuit diagram. in the hope that my problem can be solved with it.
  5. Schnudedungger
    Apr 23, 2021
    14
    6
    Hammer S
    Thanks for the answer. the problem with telephoning with the specialist is my poor english.
