While the TB is off be sure the air passage holes just under the butterfly plates are clear.
Good Morning, 🌄 Just woke up after another very late night.
Throttle Body or TB for short, is back on there now.
When it was off this time I thoroughly cleaned off the RTV from both surfaces with my thumbnail ( works great no scratching) then 'rinsed' with
TB Cleaner sprayed over surfaces spraying into those holes in question plus the small holes in the TB mounting plate, then followed up with a good blowout with compressed air from my air blower, as I would Carby parts.
Now the RTV was advised to be a "thin smear" and that's all I used, the minimum for coverage of the mating surfaces staying clear of Venturis and small holes.
Mated tightened very lightly and left for a few hours then tightens properly after.
Taking care not to overtighten and possibly warp the mating like you can bolting a carburettor down to hard
On test ride bike idled 'ok' and performed 'ok' , the tune I'd obviously out because there's no "lope kit" intake boot mod that the engine was super tuned to.
TPS needs reset too as after 30 mile nightride I pulled up at my garage door left the bike idling for a few minutes while I went inside and opened the main doors.
Came out got on the bike , turned it off ...waited ten seconds turned it back on and started it....
The idle went 'fluffy' again straight away.
I put the bike away..
