If TPS is removed or replaced it must be recalibrated using Digital Wrench. Rylan Voss might have a home shop work around. [email protected]
Dunno...what's a potentiometer..Could the internal potentiometer of the TPS be different even though the exterior is the same?
I'm in Australia, where'd you get that info from...I don't like the sound of thatIf TPS is removed or replaced it must be recalibrated using Digital Wrench. Rylan Voss might have a home shop work around. [email protected]
Thanks so much! @md2420
2007 service manual goes thru procedure using Digital Wrench. Saw md2420 info from Vic Shop hope it helps.I'm in Australia, where'd you get that info from...I don't like the sound of that
You are welcome. There could be a diff with your bike vs the V92s, but this is the only one I could find right off. I do recall another one where Rylan walked through measuring the clocking of the TPS on the throttle body, but couldn’t find that vid again. I do recall him saying that you need to mark exactly where it aligned when you took it off vs putting it back on as they are sensitive to the nth degree.Thanks so much! @md2420
So both TPS are good, but the variable resistors are slightly different in value. It's starting to sound like an electronic recalibration is necessary, with the Digital Wrench.Ok, I've just refitted the original TPS and tested it with multimeter onto the piece of MIGwire that's shoved up the Signal wire on the connector.
It's tests as good , no big jumps or dropbacks in volt numbers, nice smooth progression from
.55v closed to 4.27 wide open.
Tested twice, then did the key on count to five while opening throttle thing, won't go into that in detail...Retested and readings on multimeter are exactly the same.
I'm gonna refit the tank and see how she runs.
Found that oil temp sender location that's on Rylans last vid but I won't mess with it till I've tried running it how it is now.
The old "don't change more than one thing at a time" trick...
Now Kev (Arrow) probably the best Vic tech in Australia hasn't got the old shops digital wrench, he suggested I call the Polaris Indian shop at Southport here and get them to plug it in and do a reset...I'll try that on Monday.
Right now it's Sat lunchtime and I'm gonna do as much as possible before sending it to someone else(and there's the matter of getting it there if it's still unrideable as it was last time I rode it..
Updating on here may help someone else, it's also definitely helping me, with the input I'm getting from members on here.
Also it helps me get stuff out of my head and written down so I have a clear head and some record of what I'm doing.
For those that like pix here's one of my MIGwire piggyback onto the Signal wire, it can stay put till this fiasco is resolved🙂 View attachment 639330
Haha
