Power Vision CX Maps | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory General Discussion' started by Chatty, Jan 25, 2020.
  1. Chatty
    Chatty Member
    Nov 30, 2019
    90
    30
    HIGHBALL
    Hey fellow vic riders. I am in the UK and have a Pvcx for a tune but cant be done for some time as I am so busy and the garage I am using also busy.
    To that end does any one or is any one willing to send me a pvcx map so I can run the bike until its had a proper tune?
    My setup is...
    13 highball
    Lloydz vm1 cams
    Lloydz torque tubes
    Lloydz quarter throttle turn
    Conquest customs UD pulley
    Conquest customs ground pounders
    A map matching this setup would be amazing.
    This would see me through until I can get it to the shop. Much appreciated!!
    I have a guy Duncan willing to help me out but a closer setup is ideal
  2. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    5,534
    2,308
    Littlestown
  3. Chatty
    Chatty Member
    Nov 30, 2019
    90
    30
    HIGHBALL
    No I havent. Didnt think of that and didnt think they would hold maps for the builds we do on victorys . But will check later.
    But having a map from some one with the same build on a 106 motor would for some reason seem better haha more trust worthy..
  4. jmstang302
    Aug 18, 2013
    5,534
    2,308
    Littlestown
  5. Chatty
    Chatty Member
    Nov 30, 2019
    90
    30
    HIGHBALL
  6. Chatty
    Chatty Member
    Nov 30, 2019
    90
    30
    HIGHBALL
    Doesn't have maps that work with the pvcx sadly..
    Need some one with pvcx and a map willing to share until I can get it to a shop
  7. jmstang302
    Aug 18, 2013
    5,534
    2,308
    Littlestown
    Forgot you needed "CX" maps
  8. Andytwodogs
    Andytwodogs Well-Known Member
    Jan 17, 2014
    513
    264
    New England, NSW Australia
    '15 Cross Country LE
    I would contact Dynojet. Their customer support is very good. They will likely be able to furnish you with a map that will be ok but don't expect perfect. Or they will give you advice as to what to do otherwise.
    If you are able to buy (expensive), borrow or hire a WBCX wideband kit Fuel Moto USA has a remote tuning service. I have used this service and can recommend it.
    Considering the costs involved, you may be best off taking the bike to a reputable dyno tuner. Be aware that not all dyno tuners are created equal. Ensure the one you use is experienced with ECM tuning.....most only know fuel controllers and that skill set won't cut it.
  9. Duncanv80
    Duncanv80 Member
    Jun 8, 2015
    38
    36
    West Yorkshire . England
    custom victory kingpin
    I’ll send my map over later this week - should be a close match as the mods are the same apart from the exhaust
    • Winner Winner x 1
  10. waterhog
    waterhog Well-Known Member
    Sep 27, 2017
    724
    287
    Indiana
    '16 Victory Vegas
    The tables by Duncanv80 should work out but just in case there are issues: the trickiest part is the VE table. More folks on VOG seem to have used Maximus and the VE table from Maximus should work equally well. They just need to save the table as an excel file or take a screen shot. Same goes for timing and AFR but these are more easily adjustable. Good luck.
  11. Chatty
    Chatty Member
    Nov 30, 2019
    90
    30
    HIGHBALL
    So I had a blast today. And it seems a bit hesitant at low revs. Not sure if its starving or flooding. Doesn't feel very nice at moment to be honest
  12. waterhog
    Sep 27, 2017
    724
    287
    Indiana
    '16 Victory Vegas
    Without a decent VE table, playing around with AFR and timing will be a crapshot. Hopefully a couple of them Maximus tuned guys with similar mods can send you their VE tables so that you have multiple options to try out. PVCX, Maximus it's essentially the same. As to Dynojet, their customer service is excellent but their canned Vic PVCX tunes, from my experience and others, hasn't been positive.
  13. Kutch801
    Kutch801 Member
    Nov 28, 2019
    44
    26
    2013 Highball and 2006 Honda cbr1000rr
    @Chatty where was the map out of?
  14. Duncanv80
    Duncanv80 Member
    Jun 8, 2015
    38
    36
    The map was off my bike - 106 kingpin with Lloyd’s 505 cams , torque tubes and a 2 into1 exhaust. The map was done at Dynojet uk’s head office on their dyno. Thinking about it, if Chatty is running VM1 cams then it might be over fueling at the bottom end? The VM1 cams make a little more power at the top end, the 505 make more at the bottom end .
  15. Chatty
    Chatty Member
    Nov 30, 2019
    90
    30
    HIGHBALL
    I have accumulated a few maps now, currently running @Duncanv80 map from his kingpin which works fairly well after a certain rev point, at the low end I am getting a bit of starving/flooding cant tell yet.
    I also have a tune for my listed upgrades from dynojet but I haven't tested this yet and probably wont as they didn't give me any detail on the tune, just sent the file... which im not happy about! I was expecting a little explanation on how they decided to put their tune file together..
    the third file I have got in from BSD performance and they took my Stock file and edited the Fuel values only to suit a modified bike, this is them just helping me out until I can get it to their shop for the final tune. again not tried yet.
    but... I do have 3 PVCX maps now for any one out there needing any, pretty happy with the software and minor editing too if they need it for a quick fix.
    thanks again Dunc80
