Permanently attaching a battery tender ring terminal y | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by Maximumbob, Nov 20, 2020.
  1. Maximumbob
    Maximumbob New Member
    Jun 18, 2017
    2
    2
    Wisconsin
    2016 Cross Country Tour
    Hi all,
    I am looking for advice/suggestions for permanently attaching a ring terminal harness for my battery tender junior to my 2016 CCT battery.
    My polaris atv and my Honda Shadow both had these when I bought them and they are easy to reach but also tucked away nicely while I'm riding.
    Due to the location of the battery on the CCT I'm not sure where I should run the cable so that it is accessible but also not going to cause any problems (or melt from the engine heat).
    Has anyone done this for their battery? Or am I going to have to remove the front cover every time I want to trickle charge my bike?
  2. walks35
    walks35 Well-Known Member
    Sep 18, 2009
    773
    411
    NW Burbs of Chicago
    2004 Victory Kingpin
    I bought extensions for various purposes off of Amazon for a few bucks. You can trim it or change the terminals if desired. It's long enough to route as needed too. I run this from a terminal block up to my handle bars for charging my phone. I took my tank off and zip tied it along to existing cabling. I'm on a Kingpin which makes it easier. Good luck and welcome to the VOG!
    https://www.amazon.com/gp/product/B079ZTBHYK/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
  3. nakota7
    nakota7 Active Member
    May 24, 2012
    550
    121
    Ashburn
    Cross Country
    I have mine run on left side past cooler ticked into wire bundle. Been there 8 years with zero issues
  4. Pauljp
    Pauljp Well-Known Member
    Nov 28, 2013
    1,119
    662
    Quebec Canada
    2014 Cross County Tour
    You could do what @nakota7 said and tuck it under the plastic cover in front of the motor. Easily accessible there.
    With my 2014 CCT I simply plug it into the power socket on the left side of the fairing. It is always on and will keep your battery charged.
    I have it plugged in all winter for 5 months and it starts right up in the spring.
    • Agree Agree x 5
    • Winner Winner x 1
  5. Daddio
    Daddio Well-Known Member
    Dec 31, 2012
    1,503
    335
    heart of the Black Hills
    '13 XCT Road-Grime Brown, '09 Buell XB12XT Ulysses, the faster black one
    I ran mine into the left glovebox in the fairing lower.
  6. Storm58
    Storm58 New Member
    Mar 23, 2017
    13
    1
    Victory cross country tour
    There is no need for one on the XCT. Use the plug in the left lower box. It carries electric both ways while the ignition is off. Well electric always travels both ways, lol. I have CTek 'tails' on all my other bikes and just bought the connector lead for the XCT.
  7. PDXLaserGazer
    Jun 3, 2013
    3,944
    1,337
    Molalla, OR
    I have mine zip tied to the underside of the top forged bar brace on the left side. Easy access and away from everything else.
  8. Bikesofbrads
    Top Poster Of Month
    May 16, 2020
    756
    450
    South eastern ohio
    2015 victory cct & 06 katana
    Mine too is tucked in under plastic cover in front of motor by oil cooler, never an issue, always easy to get to. Came on the bike
  9. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    4,108
    1,531
    Littlestown
    Mine it tied to the harness on the left side by the tank, I plug my heated gear in there
  10. MacDony
    MacDony Active Member
    Jan 21, 2015
    108
    91
    France - Anjou
    Hi,
    Like Pauljp, I have always used a maintenance charger with a cigarette lighter plug plugged into the topcase ;)
    • Agree Agree x 3
  11. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    10,378
    4,207
    South Florida
    2011 Cross Country
    Yeah this one. I don’t care to stack my battery terminals with anymore items than I already have. Amp and auxiliary lighting are enough.
  12. Blowndodge
    Blowndodge Well-Known Member
    Jan 31, 2013
    1,968
    610
    Utah
    2013 Victory XCT
    Mind tender is plugged into the dash socket since it's always hot. Never had an issue.
  13. Bikesofbrads
    Top Poster Of Month
    May 16, 2020
    756
    450
    South eastern ohio
    Sorry stupid question, so the battery tender maintains the battery while powered by the bikes battery? Or is the tender plugged into the wall & maintains the bikes battery through the charging port? I’m looking into a new tender & am a lol outta date on today’s tender capabilities.
  14. Pauljp
    Nov 28, 2013
    1,119
    662
    Quebec Canada
    The tender is AC operated and is plugged into a wall outlet. Then the other end is connected to the battery of the bike either with alligator clamps, ring terminals or a socket connector which is usually included with the tender.
    I use the Optimate 4 as seen below, but there are many varieties.
  15. 1stVictory
    1stVictory Well-Known Member
    Feb 14, 2012
    6,087
    1,439
    Edmonton, AB
    2012 Pearl White CC Tour
    Before taking delivery in April 2012, I had the dealer install the case mount power socket. It does double duty, though just one at a time. Plugging in the Gerbing heated jacket liner plug as well as the battery maintainer. It's too bad that douchebag Wine headed up the destruction of our motorcycle brand. These things would likely still be available. I believe John Deere parts dept's still carry the socket and plug assemblies for quite cheap. It;'s the same style as the BMW plugs but without the spring loaded door. Also about $100 cheaper!
