Penske rear shock install advise. | Page 2 | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by burbansk, May 24, 2021.
  1. wvrider1
    wvrider1 Well-Known Member
    May 20, 2012
    3,912
    1,254
    WV Appalachia
    Goldmist/Black 14 XCT
    Look at the 2nd post in this thread
  2. burbansk
    burbansk Member
    Dec 22, 2019
    85
    69
    Michigan
    2013 Victory Cross Country Tour, 2000 BMW 1150 GS, 2008 Honda TRX 700 XX
    I understand but then why is the air valve pointing to the left side of the bike where you cant get at it? In the Witchdoctor video they show the air valve pointing to the right side of the bike. At first I had it your way then I switched it around. Please know that I am not trying to argue with you I just want to do it right this last time. By the time I get this done I will be able to do it in my sleep. LOL........... Thank you so much, I will go out and look at the inside part of the swing arm. Bruce.
  3. burbansk
    burbansk Member
    Dec 22, 2019
    85
    69
    Michigan
    3rd times a charm. Just finished it up, boy there isn't much room between the spring and the swing arm. Can't see the air valve at all, it is buried in the LH side of the frame. Thanks for all the help and information. Now if it would cool off just a bit I could go try it out.
  4. Chris_TX
    Chris_TX Member
    Apr 1, 2016
    54
    7
    Katy, TX
    2017 CCT, 2002 Yamaha Warrior
    just a note, a normal person should never touch that air valve. That is for servicing the shock, not adjustment. If i'm wrong, i'm sure someone will correct me. lol
    • Winner Winner x 1
  5. wvrider1
    May 20, 2012
    3,912
    1,254
    WV Appalachia
    I don't think you are wrong and maybe @PreachSF can chime in. It comes adjusted for your individual needs.
  6. Bikesofbrads
    May 16, 2020
    2,234
    1,293
    South central/eastern ohio
    2015 victory xct & 06 katana
    Yes, the shrader valve is for servicing & probably shouldn’t be touched by us mere mortals. The big nut up top is to adjust preload ie lowering the nut ( tightening )will stiffen the spring & raising the nut ( loosen ) will soften the spring. The thumbwheel on bottom end of shock is for adjusting the rebound, if you order a shock from conquest or penske they will make sure you get the correct spring for your weight / style & can set it close for you but once it’s installed you really should adjust the sag (by turning the big nut on top ) and then dial it in even better by using the thumbwheel on bottom. The Penske also allows you to adjust the bikes ride height via the clevis on bottom end of shock. If your the tinkering type you’ll enjoy the riding, data logging, adjusting the shock & repeating, many have just left it alone from Conquests initial settings without complaints. If your riding style is aggressive, ride two up, if you put a lot of weight on the bike or if you ride lots of curvy roads a suspension that’s on the little stiffer side does best. Setting your sag is the most important part of having a good, full motion range, comfortable, smooth suspension & the best quality of ride.
  7. PreachSF
    PreachSF Well-Known Member
    Dec 3, 2012
    1,696
    1,099
    Delray Beach, FL
    The shock is Nitrogen filled, DO NOT TOUCH THE SCHRADER VALVE ! It is only there for servicing the shock.
  8. wvrider1
    May 20, 2012
    3,912
    1,254
    WV Appalachia
    Thank you sir!
  9. PreachSF
    Dec 3, 2012
    1,696
    1,099
    Delray Beach, FL
    more than welcome!
  10. MMOOSE
    MMOOSE New Member
    Aug 5, 2014
    4
    2014 Cross Country
    Hello, I am looking to purchase one , IS IT WORTH IT?
  11. Chris_TX
    Chris_TX Member
    Apr 1, 2016
    54
    7
    Katy, TX
    Absolutely! I'm one of the ones that had issues with the oem air shock from the first year i owned it. My bike rides like it should have from the factory, now. Wish I would have done it years ago
    • Winner Winner x 2
  12. wvrider1
    May 20, 2012
    3,912
    1,254
    WV Appalachia
    I have no regrets.
    • Winner Winner x 2
  13. burbansk
    burbansk Member
    Dec 22, 2019
    85
    69
    Michigan
    Yes I am very happy with my Penske shock. High quality product , I have owned Ohlin shocks, Wilbers, Kings, Fox, and Hagon . This shock rates right up there with the best and is well worth the money.You will not be disapointed if you choose to go this route.
    • Winner Winner x 2
  14. PreachSF
    Dec 3, 2012
    1,696
    1,099
    Delray Beach, FL
    just an FYI on these shocks right now ..... we are STILL waiting for Penske to finish another run of these shock bodies for us. Been waiting MONTHS, so i apologize to anyone that wants to pull the trigger right now.
    We have been calling almost every day to try to find out why the hell this is taking so long. There is a large demand for these this year, and we have never had this much of an issue getting Penske to build these shocks. But, whenever they finish these up, we are the first ones to get them in stock.
  15. Alwhite00
    Alwhite00 Well-Known Member
    Sep 13, 2020
    431
    283
    Victory
    What's the price on these whenever they get back in stock?
