Penske rear shock install advise. | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by burbansk, May 24, 2021.
  1. burbansk
    burbansk Member
    Dec 22, 2019
    85
    69
    Michigan
    2013 Victory Cross Country Tour, 2000 BMW 1150 GS, 2008 Honda TRX 700 XX
    Hello all, My new Penske rear shock for my 2013 Victory Cross Country Tour will hit my door tomorrow if UPS is on time. Does anyone have any advise or tricks on the install? I have watched the Witchdoctor video and I am a very good mechanic. Do I need to remove the rear wheel or just the seat and side covers to do the R&R? Thanks for any info and pictures. Bruce.
  2. wvrider1
    wvrider1 Well-Known Member
    May 20, 2012
    3,912
    1,254
    WV Appalachia
    Goldmist/Black 14 XCT
    I had my tire off because I was doing other stuff. Getting the lower clevis over the spacers was the biggest challenge.
  3. walks35
    walks35 Well-Known Member
    Sep 18, 2009
    1,033
    628
    NW Burbs of Chicago
    2004 Victory Kingpin
    If you got the tools and the time it's easier to get crap out of the way. I have a Pin which is much less effort getting to the shock to replace but I also removed the rear wheel for other work and it was pretty easy to do.
  4. burbansk
    burbansk Member
    Dec 22, 2019
    85
    69
    Michigan
    Thank you WVrider for the picture. From the looks of your picture the bolt hole goes to the rear of the bike. I will take my rear tire off, it is no big deal.
  5. burbansk
    burbansk Member
    Dec 22, 2019
    85
    69
    Michigan
    Thanks walks35 I have a few different types of lifts. Did you grind the lower portion of the air shock like they say in the Witchdoctor video?
  6. Chris_TX
    Chris_TX Member
    Apr 1, 2016
    54
    7
    Katy, TX
    2017 CCT, 2002 Yamaha Warrior
    I was prepped for a major event but mine changed out super smooth. I had it up on my lift and then raised the fender up with a scissor jack. I had zero issues getting the old one out. Take you time, don't rush, make sure you have the max space available between the fender and the tire. I didn't have to grind or cut anything. I also didn't remove my tire
  7. burbansk
    burbansk Member
    Dec 22, 2019
    85
    69
    Michigan
    Thank you Chris for the positive info. I shall do just that. My shock arrived yesterday and it looks quite impressive. Do you guys let the air out of the old shock before removal? The Victory repair manual shows removing the air shock with the push rod attached to the upper shock. Here is a pic of the new shock before installation. 20210525_184649.jpg
    • Winner Winner x 1
  8. DAVEofSAC
    DAVEofSAC Well-Known Member
    Aug 15, 2015
    1,261
    611
    Sacramento/Antelope
    2014 Vision
    Part of rear tire removal's shock uncouplin'. So, anyone who's done a rear tire knows the drill. As other's have said they were doin' stuff to the rear tire so, yah, the shock was unbolted.
    YES! By all means bleed the ol' rear shock before removin' it. As mentioned, after uncouplin' the shock, 'n maybe unboltin' the upper swing lever portion, the shocks will slide in 'n out, from the top, quite easily.
    Usin' a scissor jack to lift the bike's weight off the shock's a GREAT help as well.
  9. Chris_TX
    Chris_TX Member
    Apr 1, 2016
    54
    7
    Katy, TX
    My shock seal was blown so it was totally drained of air when I did mine. Don't forget to take off the tip over switch. You'll be fine. It's much easier than it's made out to be. I had mine switched out in about an hour.
  10. burbansk
    burbansk Member
    Dec 22, 2019
    85
    69
    Michigan
    Chris TX, I finally found some time to work on my rear shock swap. I have the lower shock and sway bar mounts off, the bike is raised and swing arm lowered. I have the lower shock mount moved past the swing arm by using the grind down trick from the Witchdoctor video. My question is besides using a long 17 mm box wrench and muscling the bolt out is there any other tricks? You said that you had yours done in a hour and I am past a hour already. I am also trying to leave the top mount off the sway bar on the connecting bar or what ever they call it. Thanks for any help.
  11. Chris_TX
    Chris_TX Member
    Apr 1, 2016
    54
    7
    Katy, TX
    remove the entire shock rocker assembly, pushrod and all, as one piece. Once it's loose from the top, you should have no problem removing any bolts remaining. Don't forget to take out the retaining screw from the top of the fender so the rod holding the rocker assembly slides out.
  12. s-glide76
    s-glide76 Member
    Apr 21, 2015
    94
    55
    Phoenix, Az
    15 Victory CCT, 15 Triumph Scrambler, 97 Electra Glide, 76 Superglide, 06 Kaw KLR 650..
  13. burbansk
    burbansk Member
    Dec 22, 2019
    85
    69
    Michigan
    Chris, Thank you for the info. I now have it dropped down low so I can remove the top shock bolt and back nut. S-glide76 thanks for the video, I had already watched it and did the grind down trick as mentioned above. The only problem with this video is they don't show you the top mounts mainly the rocker guide pin. I thought that I have seen many different shock set ups in my time but as they say you learn something every day. Thanks again to all for the help. I will post when I am done with it if I can find any time between work and life to get back in the garage. Can't wait till I retire in 196 days. LOL...
    • Like Like x 3
  14. burbansk
    burbansk Member
    Dec 22, 2019
    85
    69
    Michigan
    Guys I have the new shock and push rod installed but before I finish bolting it up could someone please post a picture of how the lower mount should look. Right now I have the flat side to the front. I have seen pictures of it both ways. The way I have it now makes it easy to get at the air valve. The way I had it before you could not see the valve it was hidden under the frame. Thanks, Bruce.
  15. wvrider1
    May 20, 2012
    3,912
    1,254
    WV Appalachia
    flat side goes to the rear. The offset or bolt head goes toward the rear off the bike. If you would look on the inside the swing arm isn't machined as much. It would bind the shock when the suspension collapses.
