Do you have a Service Manual? Big help to see the panels. A plastic pry tool is a huge help.
Open the Gas and Glove box
Pull the panel off in front of the seat from the top.
Remove seat, 2 screws at front, pull up and towards the front of the bike. Unplug cable for the heated seat at the rear.
The piece over the speedo has to come off. This is where a plastic pry tool comes in handy. Will justpop off.
There are 2 bolts in the front of the dash and two in the rear, take those out, remember theground wire on the right lower bolt (towards the seat) when reinstalling. There is one more small bolt on the left side that is black that also needs to come out.
You can now lift the dash up, but have to unplug all the connections.The ones at the top you need to write down where they go if you do not have amanual. There is a large Connector for the radio and the last is the antenna. I have done this a few times and seems to be easier to do standing on theside. Should come off.
You should know get a view ofpanels.
