I just did my own oil change at 2500 M. / 4000 Km. The dealer did the initial service. The shop manual for the 2010 Vic Vision says the oil capacity is 5 U.S. quarts but shows in brackets, 4.5 U.S. quarts for an oil and filter change.
I put my bike on the centre stand on level ground, drained all the oil from the c. case and pulled the filter as well. I added 4.5 quarts, measuring the last half quart into a measuring cup before adding it to the c. case. The Vic oil change kit actually comes with six U.S. quarts.
I did a short test run then checked the dip stick (I have one of the Vic. oil temp sticks). The level linesare very difficult to see so I clean it dry and wrap some blue painters tape above the upper mark to make it easier to see the exact level. Just don't forget to pull the tape off before you go for a ride. It showed way too much oil. I used a hand pump and pumped out about 8 onces then re-checked the level. Still too much! So I pumped out another 8 onces. Now about a eight of an inch above the upper line on the stick. So this brings the total oil installed back downto 4 quarts.
What are other Vic. Vision riders finding that they are putting in during an oil & filter change???
