Not impressed with Steinjaëger's shift linkage, at all | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by Havoc70, May 21, 2021.
  1. Havoc70
    Havoc70 Member
    May 10, 2021
    40
    35
    Suisun City, CA
    2012 XCT
    The shift linkage I ordered from them is huge! Which might be a good thing. But what's not a good thing is that it won't adjust, at all. One end of the linkage is seized completely. The other end was able to adjust, but when I took out the bolt, the bolt was rather rusty and the whole inside of the linkage seems to be covered in it.
    So now my choices are either go to the hardware store and find some threaded rod the same size as my stock linkage and get it cut to size, wait until June 21st (if even then) for my other linkage to arrive, or move the controls back to the middle position which really isn't an option.
    Can't say I'd recommend Stenjaëger's shift linkage at this point, but willing to give their customer service a chance to make it right.
  2. VicVisionBulldog
    Top Poster Of Month
    Mar 27, 2011
    22,612
    10,102
    Houston
    Have you tried turning the rear linkage attachment a tooth or two at the shifter shaft? May not be perfect but may get you close enough to wait on the other parts.
  3. Chattanooga_Mark
    Dec 25, 2009
    5,390
    2,395
    Chattanooga
    2012 CCT, Wonderful in white
    Receiving rusted parts like that is completely unacceptable. If you haven't yet, try adjusting the shifter arm on the shift shaft as @VicVisionBulldog suggested above. Different length threaded heim joints can oftentimes be purchased locally, and certainly online, to add more length to your current shifter arm.
    I may be a bit unclear of exactly what the item is you posted. But I think it's a threaded end that goes on to your current shifter linkage. If not, please advise. The close up picture certainly shows the rust but not exactly what the item is.
  4. Havoc70
    Havoc70 Member
    May 10, 2021
    40
    35
    Suisun City, CA
    2012 XCT
    It's the inside barrel of the "new" shift linkage. Plus it's just too damn big for the bike. I need to know the pitch of the shift rod. I know it's an M6 (6mm) but not sure of the pitch. But, when in doubt, build it yourself. 220mm M6x1.0 rod, 5 LH, and 5 RH helm joints and that should give me more than enough. So now I have an abundance of helm joints, I might just make some to sell.
    • Winner Winner x 1
  5. Havoc70
    Havoc70 Member
    May 10, 2021
    40
    35
    Suisun City, CA
    2012 XCT
    That's the weapon of last resort. I don't want to risk messing up the shifting geometry. I have time, my refresher MSF course isn't until June 3rd and 4th.
  6. VicVisionBulldog
    Top Poster Of Month
    Mar 27, 2011
    22,612
    10,102
    Houston
    I had to move mine when a added a heel/toe shifter. Feels all the same. Just mark it, or it may have aligning dimples if I remember correctly, so if you don't like it or need to return it once you get the parts it will be a known spot. All you need is a 10mm.
  7. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    5,534
    2,308
    Littlestown
    Find someone with a welder. Cut the OEM rod in 2 and add an inch. Sand it down and paint it black or silver.
  8. RidingAgain1025
    RidingAgain1025 Member
    Oct 24, 2020
    82
    49
    Palm Coast FL
    2013 victory cross country
    Can always just order this for $13.
    Shifter linkage
    210mm seems to be the ticket but you may find 220mm works better.
  9. Alwhite00
    Alwhite00 Well-Known Member
    Sep 13, 2020
    495
    348
    Victory
    The 210 works great on my XCT
  10. Havoc70
    Havoc70 Member
    May 10, 2021
    40
    35
    Suisun City, CA
    2012 XCT
    I have one of those arriving somewhen. With shipping from China being as long as it takes, who knows when it will get here. So I have that and I'm building a 220mm Wednesday when the parts get here, so I can decide which on works better.
  11. Havoc70
    Havoc70 Member
    May 10, 2021
    40
    35
    Suisun City, CA
    2012 XCT
    So I will say that Steinjaëger's customer service is awesome. They said they'd just refund the rusted (and too large) linkage, no need to send it back. Now that's service.
  12. Havoc70
    Havoc70 Member
    May 10, 2021
    40
    35
    Suisun City, CA
    2012 XCT
    So here are the linkages.
    Top: stock extended as much as practical.
    Middle: 210mm off eBay
    Bottom: 220mm I built (not extended at all). I have 9 helm joints left over. Time to make some to hopefully sell to just cover the cost. Mine is machined and made in the USA. 3D7DDCE3-6042-4474-9E02-2C6CADAF42A1.jpeg
  13. Havoc70
    Havoc70 Member
    May 10, 2021
    40
    35
    Suisun City, CA
    2012 XCT
    And with the other two adjusted out. B35D272E-5636-45DF-B066-003CDBF52A7E.jpeg
  14. Havoc70
    Havoc70 Member
    May 10, 2021
    40
    35
    Suisun City, CA
    2012 XCT
    And linkage installed. The forward jam nut was the hardest part LOL. AD7943E1-A482-4015-A054-175500574960.jpeg
  15. primethious
    primethious Well-Known Member
    Aug 14, 2013
    8,041
    2,478
    2012 Victory Cross Roads
    Some may only measure the rod and not center to center.
    The 210mm on ebay works perfectly for the forward setting.
    Liked it so much I bought two extras for future use.
