1 - 6 of 6 Posts
Went for first ride today and all was good but on my way home I had no idle when pulling up to stops. OK if I hold the throttle open a bit and runs great just all of a sudden the idle circuit disappeared.
2013 Vision with 60,000kms on it. Heading for Louisiana in a couple of weeks so if anyone has had this issue please jump in with your suggestions. Basically stock bike except cams and fuel commanderV. Had this issue once before but it went away.
Stewart
First thing I'd look at are the vacuum lines. Look for loose ends, cracks and just plain spongy looking rubber.
Did your battery run down over winter? Might want to clean and tighten battery. Also may want to do iac reset. @NOEMTZ may know more about how you do that or do a search for iac reset, also tps reset.
IAC reset
1. Key on, red run switch on.let pump prime.....engine off do not turn on.
2. Turn red run switch off....wait for IAC to chatter.
3. Repeat #1 and #2
4. After #1 and #2 have been repeated twice .
Start bike
1 - 6 of 6 Posts
