Hello, my cruise control on my 2016 CCT will not engage, It will light up when I turn on but not set a speed, Also Heated grips are not working. are both of these connected to a fuse and if so where is it?
Do you have any aftermarket brake lights attached?I just bought a 2011 XC. The green lighting the speedo will flash one time when turning the cruise on and won't set. Ive tried cleaning connections, disconnecting the throttle cable connectors. Read about the lash and learn procedure and tried that too but nothing's worked.
Any help for a newbie would be much appreciated. Had a 2010 and never had a problem with the cc.
If you do, disconnect them and try the cruise.
I had to ask as people who install Sabertooth lights or trailer hitch wiring or something attached to the main brake signal will usually have a cruise that no longer works.I dont see any and brake lights work normally when pressing had or pushing foot brake.
Did you try the diagnostics for the cruise control? I made a video here to help you.
nah, should be fairly loose. Also check to make sure the zip ties on the right side of the frame in front of the tank aren't tight, pinching the cables and if you have forged bars, make sure the top covers aren't pinching the cables as well. If you disconnect one of the connectors on the cable under right side of tank, does it stay on? If so, the switch in the cable is stuck closed, could try to work it free from the throttle body side maybe. Or leave it disconnected and cancel cruise with on/off button, clutch or brake.
