New Oil FYI for Vics?? | Page 3 | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory General Discussion' started by El_Spanky, Mar 21, 2016.
  1. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    5,534
    2,308
    Littlestown
    Excuse me. I stand corrected. V92= 6qts.
  2. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    11,969
    5,147
    South Florida
    2011 Cross Country
    Spectro 20/40 has been out a few years. Kyle (KMC) told me about it.
  3. Jeb27
    Jeb27 Well-Known Member
    Jun 17, 2014
    4,158
    1,171
    Victory Vision 2014
    Is that the James Bond oil? ;)
  4. slickvic
    Dec 22, 2011
    11,969
    5,147
    South Florida
    2011 Cross Country
    It is a semi synthetic. Made in my home town Brookfield CT. I never used it. Prices the same as Amsoil and only a semi syn. Still a good Motorcycle oil made by people who live motorcycles.
    I wouldn't think twice about using it. Kyle says it's good then it's good.
  5. Angryinri
    Angryinri Active Member
    Jul 18, 2015
    126
    58
    Warwick ri
    2003v92
    I'm switching to amsoil for my first time. I ran mobile 1 last year an motor seemed louder than the Vic oil in my v92
  6. slickvic
    Dec 22, 2011
    11,969
    5,147
    South Florida
    2011 Cross Country
    You can use 10/40 or 20/40. Not sure of the recommendation for the V92 but 20/50 seems to quiet these Bikes down significantly. If you have catalytic converters then the 20/40 is recommended.
    I ran 10/40 for 4 years and just recently switched to the new formula 20/40. Still smooth and quiet. Shifts great. No noise. Really impressed with my Vic motor compared to the horror stories I heard of others.
  7. Roadkill
    Roadkill Roadkill
    Oct 19, 2015
    21
    17
    Walker Valley, NY
    Victory Can-Am Honda
    +No, the 2004 Vegas uses 6 quarts of oil.
    Ride on.
    Roadkill
  8. Roadkill
    Roadkill Roadkill
    Oct 19, 2015
    21
    17
    Walker Valley, NY
    +Do you need a best price quote?
    Simply send your ship address & phone number to me at <[email protected]>
    Ride on.
    Roadkill
  9. Roadkill
    Roadkill Roadkill
    Oct 19, 2015
    21
    17
    Walker Valley, NY
    +The Four-Ball Wear Test is comparable. Bearing skate is a myth. Scar damage and bearing wear are real.
    https://www.amsoil.com/lit/g3115.pdf
    [​IMG]
    Ride on.
    Roadkill
  10. navycraig
    navycraig Well-Known Member
    Feb 13, 2014
    1,359
    561
    Callaway
    2012 Victory Crossroads LE #258
    Call Lloyd and tell him that. Should be a fun discussion.
    • Funny Funny x 1
  11. SubDude
    SubDude Well-Known Member
    Sep 12, 2014
    2,095
    834
    South East Michigan
    16 Chieftain Silver Smoke
    Caught you Craig, said you wouldn't view any more oil threads. HA Ha!
  12. Roadkill
    Roadkill Roadkill
    Oct 19, 2015
    21
    17
    Walker Valley, NY
    +Lloyd is six miles from me, and was my main source of V92C maintenance/repair from 1999 until #2656 went to the museum and #219 was finished. We know each other quite well.
    Ride on.
    Roadkill
  13. navycraig
    Feb 13, 2014
    1,359
    561
    Callaway
    Man, you're right, I did. That was a long time ago so you have a pretty good memory. You caught me.
    • Funny Funny x 1
  14. navycraig
    Feb 13, 2014
    1,359
    561
    Callaway
    Cool. Should be quite easy for you to discuss the myth that he seems to believe in. Would honestly be interested to hear the result of the discussion.
  15. s-glide76
    s-glide76 Member
    Apr 21, 2015
    94
    55
    Phoenix, Az
    15 Victory CCT, 15 Triumph Scrambler, 97 Electra Glide, 76 Superglide, 06 Kaw KLR 650..
    AMSOIL Synthetic Oils: Slipperiness and Wet Clutches
    As a side note, we have received many reports of motorcycle shops telling customers that synthetic oil is so slippery that is causes roller bearings not to roll and will result in flat spots on the roller bearings. This is absolutely not true. Synthetic oil is no more “slippery” than petroleum oil. Synthetic oil is more uniform in molecular structure than a petroleum oil but it is not more slippery and will certainly not cause roller bearings to roll. Roller bearings will roll whether they are using petroleum oil or synthetic oil and the only way the roller bearing on the rocker arm will ever stop rolling is if the needle bearings that support the roller bearing failed. Every automotive racing engine (as well as many other types of high performance engines) and most of today’s high performance automobile engines use camshafts with sophisticated roller rockers with absolutely no problems of this nature whatsoever.
    We have also received reports of motorcycle shops telling customers that synthetics are so “slippery” as compared to petroleum oils (which simply do not reduce friction as well) that wet clutch packs in their motorcycle transmission and even their automatic transmission of their cars and trucks will slip when using “slippery synthetics” even if there are no friction modifiers present. This is absolutely not true.
    Look at it this way. Wet sandpaper removes paint as well as dry sandpaper does. The slipperiness of the water does not impede the sandpaper's ability to function. The same applies to the slipperiness of synthetic lubes in wet clutches. It is simply not an issue. However, just as rinsing the sandpaper keeps it cleaner longer so it functions better longer, so the synthetic lubricant keeps wet clutch plates cleaner longer so they function better. And, since synthetics are superior cooling agents to conventional petroleum lubes, using synthetics will help wet clutches last longer, too.
    Petroleum oils have low resistance to heat and allow varnish and glaze to form on clutch plates, which can lead to slippage and increased heat generation and potential failure of the clutch pack. Synthetic oil is going to allow your wet clutches to perform better (especially under extreme heat, RPM and load conditions) and last longer than they would with petroleum oil subjected to the same operational conditions.
    As a side note in respect to Automatic Transmission Fluid: synthetic ATF is not more “slippery” than petroleum ATF. The base fluids, whether or not petroleum oil or synthetic oil, play no direct role in the relative friction levels of wet clutches. The friction-modifying additives developed for petroleum oils work just as expected in synthetic PAO’s fluids. The longer the fluid resists oxidation, the longer the original frictional properties remain. The superior oxidative stability demonstrated for synthetic ATF’s thereby leads to extended retention of frictional properties.
    • Informative Informative x 2
    • Disagree Disagree x 1
vicssgfyi
