New Freedom Performance True Duals installed | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by jchris56, Aug 3, 2013.
  1. jchris56
    jchris56 Member
    May 8, 2012
    232
    3
    Lancaster
    2013 cross country tour
    I just got done installing my new true duals this morning. I got the chrome tip version. They look great much nicer then to OE pipes. As for the sound. It is the best sounding exhaust I've ever heard. Nice mellow rumble at idle and cruise. When you hit the throttle WOW is all I can say. The sound is amazing. Fit and finish were very good. The only thing I don't like is that the left pipe is in the way of the kick Stand. So it is really tricky to find it with my heal it put down. I hope I can get used to it but if not I might try a kick stand extention. If your thinking about them stop thinking and start ordering. In my humble opinion it is the best exhaust currently available for cross bikes.
  2. yankphan
    yankphan Well-Known Member
    May 20, 2013
    983
    297
    2011 XC
    did you have to remap the ecu ?
  3. jchris56
    jchris56 Member
    May 8, 2012
    232
    3
    Lancaster
    I was already running a VFC and my stock mufflers had thrush glass packs in them. I also have a loydz air filter. So I don't think you have to tune it. I do think it helps. It defiantly runs a heck of a lot better now then it did stock.
  4. JayFL726
    JayFL726 Well-Known Member
    Nov 2, 2012
    1,538
    359
    Lake City, FL
    2011 Victory Cross Country/2005 Dyna
    You will get used to finding the kickstand with no worries, just be careful stopped at lights for the left side Pipe sticking out a little .. Although don't take long to learn that either .. :) Other than that I think they rock in Sound and Power ..
  5. jchris56
    jchris56 Member
    May 8, 2012
    232
    3
    Lancaster
    I'm sure I will get used to it but if not I will put an extention on there. It does feel like it had more power now. I'm not sure if its in my head though. It sure does sound nice with the throttle wide open.
  6. mjw930
    mjw930 Well-Known Member
    Oct 23, 2009
    3,394
    426
    Ormond Beach
    Octane
    The way that left pipe sticks out would concern me. If I were doing these both head pipes would take a trip to a ceramic coating shop, one that does them inside and out. Properly coated headers can be touched by bare hands without burning, cheaply coated, outside only, not so much.
  7. jchris56
    jchris56 Member
    May 8, 2012
    232
    3
    Lancaster
    I was a little concerned about the left pipe sticking out. So far thought its not a problem.
  8. yankphan
    May 20, 2013
    983
    297
    2011 XC
    I'm going to be ordering these pipes soon....do I need to order anything else for them....?? I am picking up a totally stock bike next week. Please tell me anything extra I need or can I just bolt em on. The kingpin I had did have victory performance shot gun exhaust and I was "told" it was remapped ?? I heard a backfire here and there. Do I need to do this?
  9. jchris56
    jchris56 Member
    May 8, 2012
    232
    3
    Lancaster
    You will need to get new exhaust gaskets. If you are going to keep the stock air filter. You should be ok without a tune or flash. If you are going to change the air filter which I recomend then you need a flash or tuner. If you want to do get rid of the O2 sensors then you need to order plugs for the o2 ports.
  10. delawnman
    delawnman Member
    Jun 2, 2012
    85
    Trumansburg
    Victory Vegas 8 Ball
    Who makes "true duals"? And i too replaced the factory filter with Lloyds, huge improvement ll by itself.
  11. jchris56
    jchris56 Member
    May 8, 2012
    232
    3
    Lancaster
    They are made by Freedom Performance. I got mine from http://www.phatperformanceparts.com/Freedom_Performance_Racing_Duals_w_4_Inch_Muffler_p/fp-racingdual-xroad.htm Witch doctor also has them. You can google them for pics and video. They have a great sound. Nice rumble at idle and cruise and they scream when you get on the throttle. You won't get the same sound from any of the slipons withe the stock head pipe.
  12. sheikyerbouti
    sheikyerbouti Member
    Apr 21, 2013
    254
    20
    13 Hardball, Lloydz touring cams, timing wheel, air cleaner, PCV, 1/4 throttle ring, D&D pipes
    you know us...we want sound clips!
  13. JayFL726
    Nov 2, 2012
    1,538
    359
    Lake City, FL
    http://www.youtube.com/watch?v=dqmOu41d82A
    Have Posted this several times but here you go ...
  14. yankphan
    May 20, 2013
    983
    297
    2011 XC
    Did they come with the o2 sensor plugs ?
  15. jchris56
    jchris56 Member
    May 8, 2012
    232
    3
    Lancaster
    No they did not include the O2 plugs.
1999 victory v92 true dual exhaust
anyone install freedom muffler very loud
dobeck performance afr plus indian motorcycle
freedom perfoormance install victory cross country
freedom performance exhaust for victory cross country
freedom performance exhaust oxygen sensor plugs
freedom performance or hacker custom for victory cross country
freedom performance true duals victory cross country
freedom true dual exhaust victory cross country
installing freedom performance true duals on victory cross country
installing new freedom true dual header pipes indian cheiftain
what to do about 02 sensor with freedom performane pipes for an indian
