New bike home, new questions too. '08 VV | Victory Motorcycles: Motorcycle Forums
Discussion in 'Tech Q&A' started by MoparSteve, Mar 4, 2017.
  1. MoparSteve
    MoparSteve Member
    Feb 18, 2017
    73
    39
    Kirkland, QC
    2012 Vistory Vision
    Where does one have Victory keys cut. They gave me 4 keys at the "everything" dealership and only one fits my Vision.
    Next question would be how do you keep the floorboards in the up position. Mine keep falling down and it hinders movement when backing the bike up when seated on it.
    Lastly, OK, I is extremely cold 3deg F. When the bike starts up it makes a loud ticking noise then goes away after about a minute. Sounds like a sticky lifter like the old time pushrod days.
    Thoughts???? 2008 Vision Street.
    • Funny Funny x 1
  2. vision_nut
    Aug 15, 2011
    7,876
    747
    vision 08
    You have to pull the flood board pin. Slid it out holding board in place.
    now lift slowly. There is a small ball bearing under it a long with a spring.
    No spring or bearing pull other side and go to hardware store they will have what you need.
    Take keys to a real locksmith. Hardware store are not real.
    Your crazy to start bike when its that cold. Yes lifters will knock.
    Rule of thrum when below 35 degrees and your not going to ride for a hour or more let bike sit. Condensation will form in motor when you start in cold weather
    • Agree Agree x 4
  3. MoparSteve
    MoparSteve Member
    Feb 18, 2017
    73
    39
    Kirkland, QC
    2012 Vistory Vision
    Had to start it to get into the trailer. It nor I will be out until 40+ temps are here.
  4. MoparSteve
    MoparSteve Member
    Feb 18, 2017
    73
    39
    Kirkland, QC
    2012 Vistory Vision
    Thanks for all the other info!
  5. Hsns
    Hsns Active Member
    May 19, 2015
    111
    31
    Stephens City, VA
    2006 Hammer
    If they have trouble matching the key, mine (06 Hammer, but I would bet they're the same) was cut on a KW14 blank. It's a very common motor sports key used by Kawasaki, Ducati, Suzuki and many more.
  6. MoparSteve
    MoparSteve Member
    Feb 18, 2017
    73
    39
    Kirkland, QC
    2012 Vistory Vision
    More great info
  7. Oldman47
    Oldman47 Well-Known Member
    Mar 4, 2013
    6,181
    1,314
    Forsyth, IL
    2013 black Vision
    Almost any key shop, not the small arrangement at a big box store, will carry blanks for Kawasaki. The KW14 or KW15 blanks will work out fine when cut by a real key shop. My everyday key is cut on a KW15 blank but before this one I had one made on a KW14 blank that also worked great.
    These bikes have something like hydraulic lifters built into the rockers. They can bleed down if the bike is parked long enough and in extreme cold it could take a bit before you get much oil circulating to bring them back up.
  8. wvrider1
    wvrider1 Well-Known Member
    May 20, 2012
    3,995
    1,317
    WV Appalachia
    Goldmist/Black 14 XCT
    Recommend that you go to lloydz web site and read in the tech tips on how he starts a cold Vic
  9. BoilerMan
    BoilerMan Well-Known Member
    Mar 20, 2014
    2,497
    1,050
    Sesser IL
    2020 Harley FLHCS 114.
    I agree to taking the key/blank to a REAL Locksmith for a cut and they (may) be able to re cut the keys that don't work , get a KW14/15 blank just in case. The ticking will happen after setting for a longer period and starting in cold weather (3 deg, DAMN) :22yikes:.
    Tech Tips | LLOYD'Z Motorworkz
  10. MoparSteve
    MoparSteve Member
    Feb 18, 2017
    73
    39
    Kirkland, QC
    2012 Vistory Vision
    Looks like all the tech tips have been removed from the link :cry:
  11. Oldman47
    Mar 4, 2013
    6,181
    1,314
    Forsyth, IL
    2013 black Vision
    If you want the tips, view this. It is rich in information for any modern Vic except an Octane.
  12. BoilerMan
    Mar 20, 2014
    2,497
    1,050
    Sesser IL
    Well shite, they changed the website so that part may still come online later. The part that relates to this thread is the starting of a cold bike (technique), I believe it is mentioned in the Vic Shop Video OldMan47 put up.
  13. MoparSteve
    MoparSteve Member
    Feb 18, 2017
    73
    39
    Kirkland, QC
    2012 Vistory Vision
    Watched this a pile of times before even considering my Vic.
08vv forum
