I bought one blacked out switch from an Auto Zone. Matched the Heated grips perfectly. Had it done while having my accessory lights put on. Put the lights on by kuryakyn at Americade but they didn't have the rocker switch so I ran down to Auto Zone to get one. Good luck bdbaggrI don't think they are standard, but I could be wrong. I bought 2 unlit rockers from WD and took one to Auto Zone and O'Reilly's and both said they could probably order one in but neither had anything in stock that was the same size as the cutout. The one in my link for sure is the right size, however.
I was wondering about that.Ya. They pretty common. I went with a lighted one and its way too bright at night. Had to paint over the switch a bit to reduce the brightness.
WW
Same issue here, very bright blue light. I used Midnight Blue enamel nail polish. It's lasted for 3 years now and you can't tell the switch is painted.Ya. They pretty common. I went with a lighted one and its way too bright at night. Had to paint over the switch a bit to reduce the brightness.
WW
Great suggestion, thanks!Same issue here, very bright blue light. I used Midnight Blue enamel nail polish. It's lasted for 3 years now and you can't tell the switch is painted.
Hello Tightrope where did you get the switch shown in your picture?Here's a great solution for the too-bright problem...
It has a small, blue LED that matches the dash lights nicely. The matching two-position rocker on the left is for my alarm system and garage door opener.
Thanks for your help.Both of them came from Del City. I tried to look up the exact switch, but they apparently don't have the blue one anymore. Here's red, green and amber:
LED Illuminated Appliance Rocker Switches - SPST, DC Rated
