My gear sieht jumper out | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Hard-Ball' started by ughammer, Sep 10, 2021.
  1. ughammer
    ughammer Well-Known Member
    May 25, 2011
    375
    303
    Germany
    Hard Ball 2012
    I need some advice,
    My sixth gear jumps out at 160 kmh (95 miles).
    Not when accelerating but when gliding along. Also it does not jump out immediately but after a certain time.
    When I drive slower everything is ok. Also the other gears do not cause any problems .
    There is also no strange noises.
  2. kgkmav
    kgkmav New Member
    Oct 14, 2021
    11
    3
    Hardball
    I wonder if I could be a sensor? I'm still learning about these bikes. that is very strange.
  3. normthenomad
    May 19, 2018
    1,242
    714
    Check your belt tension.
  4. uk_john
    uk_john Active Member
    Jul 25, 2008
    196
    28
    London
    Cross Country 2012
    Morning Uwe
    I had something like this happen on my old Vegas when I tuned up the engine.
    The cause was a loose bolt on the gear Asm Roller Follower pt# 1341402 to check this you will need to remove the primary case.
    How many KM has the bike done now. John hopefully met up in 2021
    • Useful Useful x 3
  5. ughammer
    May 25, 2011
    375
    303
    Germany
    Hard Ball 2012
    Hello John
    I drive nit the phenomenon already the whole year. Italy, rally and many other meetings, when I drive normally or even hard on country roads nothing happens. Only on the highway at higher speedem over 160 kmh jumps out the sixth gear. I have researched that there is a small component behind the cover that wears out. I will order it times and install and measure before. Maybe you can rebuild it from higher quality steel.
    My bike has run a little over 90 thousand.
    Hopefully we can meet in 2022
  6. 08vegasrider
    08vegasrider Active Member
    Jan 16, 2021
    200
    105
    Victory vegas
    sounds like the dogs are bad on the back of 6th gear and it is popping out of gear. I just wouldn't go to 6th gear anymore if I were you. you don't need it anyway. I never used sixth until after 90 mph
