I bought this 2011 Vision used with 16,000 km on it , but I didn't really like the two tone paint scheme (pearl/grey) plus it had a few deep scratches , cracks and broken tabs on the fairings . i also didn't like the fit and finish of most of the panels , so I thought the only way to fix these issues is by taking it apart and start from scratch .. which i did
Here's what i've done so far:
1- Lowered 2" in the back and a DIY spacers 1.25" in the front.
2- Thrush Mod , but with MagnaFlow 30" Part#:18145. and 10" tips with 2.5"inlet 4.5"outlet . sounds amazing it's like a V8 and it looks factory.
3- Removed cats.
4- Deleted the O2 sensors.
5- Clear front turn signals.
6- LED HeadLight , DRL and turn signals .
7- Realigned all panels , fairings and saddlebags covers.
8- Sanded all fairings / panels and had them repainted professionally at a paint shop (Solid White).
9- Added a dark grey 16" 7jurock windshield.
10- Added a $25 Bluetooth adapter, now I can play music, map directions etc. . from any mobile via the factory stereo.
11- Added a mobile mount with its own USB charger .
12- Added another double USB charger for my other devices.
13- Did the rear turn signal mod .
14- Added red LEDs one the skirt panels above the mufflers.
15- made a bracket for both parts of the front fender that goes inside of the fender , it looks alot like the victory fix , but stronger.
16- installed the Shifter / Brake Bushing Kit .
17- installed 2 Cadillac horns , i kinda like how they sound , plus they are alot louder than the stock one .
To Do list :
1- LED FOG lights . i have a few different types to try out and i already made a bracket that would fit them all . DONE
2- Mod the saddlebags to avoid bottoming out.
3- install cup holders. DONE
All done , clean , sittin' low & ready for a ride
if you look closer there are 3 bolts holding the front part of the front fender on eachside and another 6 on the back part , you can also see the 4.5" summit tips they look alot like the stock ones and flow really well with the factory shields.
Testing the BT Adapter :
After a quick wash :
Going for a quick night ride
Update #1: test fitting one of the LED Fog lights , they are tucked under the tipovers and NO they won't hit the ground when tipped
3- Removed cats.
To Do list :
