Come to a stop, use volt meter. Everything normal.
Start moving again, check engine light comes on. No other bulbs blow from this!
Come to a stop, use volt meter (WHILE engine light on). Everything's normal. 14.35
Minute later, check engine light goes off.
Start moving again, check engine light comes on. No other bulbs blow. High beams on, 4-ways on, slightly riding breaks.
Don't stop, few minutes later check light goes out again. Does not come on again until after coming to a complete stop then moving again.
Battery 13.5V no load, key on
14.45V when bike is running
Low beam socket, 14.45V idle, 50%, full throttle, and while check engine light is on.
No exposed wiring that I can find
Dealer is useless and clueless, no ideas but wants me to drop off the bike at @120/hr. He's clearly on crack.
New Volt Reg OTW but do not want to install it as it seems that's not the issue.
Absolutely no (obvious) reason(s) why the check engine light comes on.
Gone through two (2) different brands, four (4) different "types" of H7 bulbs, six (6) bulbs total ATM, all blow as soon as the check engine light pops on.
Now I'm understanding why Victory went out of business. I should of stayed Suzuki
I had different symptoms 2 years ago... my VV blew fuses not bulbs. When wiring was static checked it rung out, when voltage was checked running it was fine, when temperatures exceeded 100 degrees I got voltage drop problems (per DVM).
As I said a static check of R/R, stator, and battery showed good (but, I changed the battery anyway 'cuz it's a good place to start). Replaced the R/R and haven't had a problem since (2 years ago mind ya)…
I'm sorry ya have no faith in yer dealer (yet, I feel the same way)….
The check engine light might be coming on due to too high or low voltage. Bulb may blow from a voltage spike. Try the regulater as long as you have it anyway.
I have, slow rolling the throttle from Idle to full throttle, the socket stays steady at 14.45V. Even while the check engine light is on, it's 14.45V
Which leads to the next question, if voltage is spiking, why isn't the other 15V high beam blowing, that is on at the exact same time? Exact same brand and quality (Sylvania Ultra).
OP, you wrote that you slowly raised the rpm's. Raise the rpm's quickly like you're riding it or if you can, ride it with the multimeter connected to the battery. I think you are on the right track but just not testing it under the conditions the problems arise. Vibration, heat, etc may provide further clues. Open and clean all the connections for the regulator as well if you haven't done that already.
I was just thinking of that a few minutes ago if the check engine light is on longer than the issue is actually happening. I think i can take the head lamp lid off, hook up the clamps, and ride safely with the volt meter sitting in there.
But still, even if the volt spikes, why would it only blow that sole 15V 55W bulb when I have multiple on at the same time? That is what has me concerned because it doesn't seem to address that issue. I've checked the wires and cannot find any cracks or melts. Should I just be focusing on a new wiring harness?
Loose batt connections, bad ground, dirty connections will cause everything you describe.
Go back to basics: start at the battery & work out.
I can't imagine a reason you'd have to connect the leads to the connectors in the headlight. Go directly to the battery if it's easier. As mentioned get a cheap (under $20) D'Arsenval (needle type) meter. You're experiencing a surge that may only last as long as the low beam filament and a digital meter won't catch that. Still leaning towards the regulator as it's a more common fault but we should try to at least prove it.
Your low beam light is getting power from a different route than the high. Also, the high may have a resistance that may allow it to take a momentary hit. As for the duration of the check engine light i could easily be that programming is watching other sensors and has a timeout feature.
Oh, and before you test any further disconnect any non-standard electrical features that were added to the bike.
Hopefully you find this soon. Over a period of time the rest of your bike won't like spikes either. That engine light indicates it effecting more than just the light.
Something is breaking down either due to vibration or load. Too low would more than likely be the stator. Too low or too high can be the regulator.
If you want to play around with it, verify all the connections and do the proper testing for both pieces. When you're testing the regulator wiggle and tug at the wires and rap on the regulator with a screwdriver handle. There's a circuit board in there with components that don't really like vibration or heat and cracked lands can be quite common in hostile environments. You still may not be able to reproduce the fault thought. Polanus is suspected for putting maybe not quite the best available tech into their wiring.
The history of related problems on the forum certainly indicates the regulator is the first choice of something going into the toilet. Lots of threads here. Also look for the details on the upgraded alternative rather than going back to Polanus.
Hook your volt meter back up to the bulb socket. Start the bike and read the voltage. should be around 14 volts. Now tap on the voltage regulator with a wrench or something. If you see spikes in the voltage, your regulator is bad. Me personally, I'd just replace the regulator and see if the problem goes away. If it doesn't you can always change it back to the original one.
I see your bike in question is a vegas low, but where are you?
I don't have shop manual specific for you bike, but my shop manual for my Jackpot (2007) shows a couple of variations for the headlight depending on bike location and bike options..
Different circuit for European bikes and different wiring for standard headlights and HID lights....
Sorry, according to my 2007, the procedure would only be for testing the ACM, all others need to have the bike connected to the Digital Wrench program at your dealership. Not sure if there is a procedure to get the error code for a 2012.
Update, finally got the volt reg, slapped it on. Volt sits at 14.55 steady now, occasionally it will hit 14.54, but it is a digital voltmeter.
Went for a short ride, check engine light never came on.
Still no explanation as to why only the low-beam was blowing, but at least I have piece of mind now that no other systems could possibly get fried from a faulty volt reg.
When my regulator started showin' signs of decay it blew my 2nd Aux fuse (that's what the fuse is labeled). Eventually I changed my R/R... but, not after much brain rackin' and harness chasein'.
Glad to hear it was a simple fix... now ya can pass it on.
I'm sorry but I'm hopin' that's 2 typo's at 4.XX VDC where it should be 14.XX VDC.
I, for one, am 'appy for ya!
It should of been that simple from the start had the high-beam blown just like the low-beam when on and the thing spiked to 18V. Maybe the 11H light is made differently and can handle the 18V where the 7H bulb cannot.
Update, maybe it should go w/o saying? My bike is running better over all with the new voltage reg. She has a nicer sound, she hardly backfires, and I don't always hear a tick coming from the oil fan! Should of done this when I first bought the bike!
Related Threads
VOG Forum
1.1M posts
49.5K members
Since 2008
A forum community dedicated to Victory Motorcycles owners and enthusiasts. Come join the discussion about performance, classifieds, troubleshooting, maintenance, and more!
