1 - 4 of 4 Posts
Ive had this rattle near the botyom right side of the engine for a while. Took the exhaust off and there seems to be this small cylindrical baffle that sits in the pipe. See picture. What's to stop this from rattling around? Is it suppose to be a tight pressed fit? ( it's not )
Looks like your catalytic converter or cat. There is one in each pipe. All I have seen are fixed into the header pipe at the rear end. Matter of fact, when I took mine out a couple of years ago it was almost impossible to get them out without destroying them. If you want to secure them, you might use something like JB weld. Maybe someone has had this problem and can advise you.
1 - 4 of 4 Posts
