1 - 4 of 4 Posts
Hi, I am going to install one of these tomorrow. I just need to know a few things from someone that has already installed one.
1. Do I just unbolt the left side bolt? The bike will be on the kickstand, so will my wheel move when do this?
2. Do I need to remove the seat to get to the wiring?
3. Any tips from someone that already installed one of these.
I have the HS-307 for my 2008 Hammer, just FYI.
Thanks
LOL. I am in the same boat guys. From looking at it though, the kick stand idea might work but be careful of the rear tire alignment before reinstalling the bolt. I would plainly mark exact location before removing nut. I just bought mine and the tracking was so bad the front tire was wore out on the left, bike leaned way over, not sure how this guy rode it. Taking the seat off for access would make life easier, but not a have too. Just my view from the cheap seats. I will be doing that one soon, but will read the advise from the pros on here first.
1. make sure your adjuster bolt is snug before you loosen the nut and you will be fine.
2. I jacked mine up by the frame to get to the wiring. It was a pain in the butt but I did not want to remove the fender. With that said I'm not sure on the JP
3. Just make sure your wiring is tight and will not hit any moving parts.
1 - 4 of 4 Posts
