You can either buy a stock timing wheel or set the Lloyds to 0. I know 801 Motorworx has stock wheels on hand for you if you need one. You dont need to buy anything but the Maximus tuner and optional tune. You will use your STOCK 02 sensors. He will send you a kit that includes EVERYTHING you will need to do the road tune with him. If you're missing your stock 02 sensors, he has those too.....I can only speak to my experience with 801 Motorworx when I say, its LITERALLY, a one stop shop!!!Does one have to put a stock timing wheel in their bike if they get the Maximus?? Didn't realize their prices were comparable to PCV "and" wheel combined.
And, would you need to purchase the TR02 WIde Band 02 sensors. I believe I have the OEM sensors in a box but if I do can they be used??
RedSawacs is correct about the "generic map." I have a 2013 Cross Country with the Maximus. With the help of Those Dyno Guys & Technoresearch I was able to get a "generic map" for the set up that I had set my bike up with over last winter. (S&S Cams, Lloyz Filter, Stage 1 Exhasut) There is quite a bit of room for improvement for it to be bike specific. By putting it on a dyno, Matt Smith at Those Dyno Guys was able to fine tune it and pull a bit more HP and Torque. On top of that my motor runs smoother, cooler, and I get better MPG than I did when the bike was stock.With the Maximus, you'll use your O2 sensors again and you WILL NOT need the Lloyds timing wheel. You will see a noticeable difference in performance with the Maximus tuner since your fuel tables will be mapped to your performance set up.
HOWEVER; if you don't do the dyno tune, you're only getting in the ball park with the "stage 1" or as I more accurately call it, "generic map". Each bike is different and a generic tune will not do it much justice. Some swear by the generic tune but I noticed a difference between the generic tune that was initially installed during the tuning process and the end result of the computer tuning process.
You will not regret getting the tuning session to go with your Maximus!!!
2 misconceptions we need to clear up here.Rylan suggested hitting them up for a tune. I was waiting for KevinX to come out this way. Bit closer and riding to Salt Lake this time of year is iffy in some areas.
Yeah, I think I got the O2 sensors somewhere but something tells me since I have what I have, might not be worth changing now. I'll only get pennies on the dollar for resale used and if it's not gonna give me much more then might as well stick with what I have.
