I used a maximus tuner to put a tune on my 15 vegas when I picked the bike up from the shop the ride home my gear indicator was all over the place and not reading what gear I was in the bike has 10k miles they tried to tell me it was a sensor but I had them recheck the tune and it turns out from what they say the tuner misread my bike as a cross country and they are waiting on maximus to send them a fix has anyone e else experienced this and what was the fix i have been waiting since November
Most of the following comments should apply to Maximus although some are specific to Dynojet's PVCX flash device that I've been using:
1. Reflash the factory calibration and check that your gear indicator is working correctly. If so, there might indeed be a problem/bug in TechnoResearch's software that uses Maximus to flash Victory's ECU. Although they've stopped supporting Maximus for Vics a while back, a legacy problem, if one exists, should be their responsibility to fix. Call them directly. They are known to have great customer support.
If the factory flash is not working fine, then the bike's speed sensor might be kaput. Gear indicators use software inside the ECU to infer from speed sensor reading at which gear the bike is in. The speedometer would usually act up though. If the readings are off by a little, maybe it's not easy to notice.
2. All 106 flash interfaces for Vics should be the same. That's certainly the case for PVCX. Any bike depencies such as XC versus Vegas will be determined at the marrying stage where the flash interface Maximus binds to your bike's specific ECU. No need to buy another interface.
Let us know how it works out and good luck.
