Maximus Tune failed, can't connect to ecm now | Victory Motorcycles: Motorcycle Forums
Discussion in 'Tech Q&A' started by McFousty, Aug 27, 2021.
  1. McFousty
    McFousty New Member
    Aug 11, 2020
    13
    14
    Massachusetts
    2012 Victory Vegas
    Hi all, I have a 2012 victory vegas. I've use my maximus a few times before, just went to adjust and slap the basic stage one tune on my bike and adjust from there. In the process of flashing the ecm the maximus just up and disconnected mid tune. This in turn caused a failed tune/flash as well as preventing me from using the recovery option on the maximus software, or forcing the base map back through. Sometimes it says vcm not responding other times it says ecu not responding etc. I think my ecm/esu is fried/bricked and there is nothing I can do. Unless someone knows something here. If it is done fore can I get a computer from another bike same model, same model ecm and use it on my vegas? I'm supposed to have it dyno tuned in 2 weeks. Thanks IMG_20210726_202030_699.jpg IMG_20210726_202030_699.jpg
  2. md2420
    md2420 Well-Known Member
    May 10, 2016
    2,554
    1,128
    Chandler, AZ
    2014 Vision
    Did you get the Maximus from Noemtz?
  3. McFousty
    McFousty New Member
    Aug 11, 2020
    13
    14
    Massachusetts
    2012 Victory Vegas
    I dont think I got it from him, but he did try helping me by forcing the base map back in and it just wouldn't take due to vcm error, or ecu not registering
  4. md2420
    May 10, 2016
    2,554
    1,128
    Chandler, AZ
    2014 Vision
    Ok…he’s the expert on the Maximus, so not sure how else to help. Maybe others will chime in, but don’t be surprised if his name comes up again.
    hope you can get it corrected.
  5. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    5,534
    2,308
    Littlestown
    Did you have the bike on a charger while installing the tune? Are all of your cables clean and tight?
    Try to reinstall the Maximus software on your laptop.
  6. McFousty
    McFousty New Member
    Aug 11, 2020
    13
    14
    Massachusetts
    2012 Victory Vegas
    Okay, cables are all good, I only have a battery tender on it right now, ill re instal the software as well
  7. normthenomad
    May 19, 2018
    1,087
    632
    Nice looking scoot. Yes you can get another ecm from same model etc. The Cross bikes and Vision are probably programmed a little different than the steel frame. Noe would know for sure.
  8. 39_chev
    39_chev Active Member
    May 12, 2012
    143
    64
    Central Minnesota
    2011 Vision Silver/Black
    I had my Vision tuned by Lloydz in Sturgis. The guy doing the tune was having trouble with similar ECU or VCM not responding/recognized. He had to get Ryan Randall at the dealership involved and he came up with a fix. Maybe talk to them and remind them that we were having a similar problem in Sturgis...
    • Useful Useful x 2
  9. NOEMTZ
    NOEMTZ Well-Known Member
    Jun 5, 2008
    1,084
    330
    Waller
    Victory & Indian
    Didn’t buy it from me. There is a way to force flash the OEM file onto ECU. The one method I tried didn’t allow the flash in either. So a quick call to techno research will get you fixed up. Those guys are always ready to help Mon-Fri. They can remote in and do it directly if in fact no other external issues like bad ports, cables, voltage or shorts.
    • Like Like x 5
    • Useful Useful x 2
  10. jmstang302
    Aug 18, 2013
    5,534
    2,308
    Littlestown
    Any luck?
  11. normthenomad
    May 19, 2018
    1,087
    632
    Noticed you still have the stock airbox, there's a brand new S&S intake here on market place for $275. With the Maximus and the Bassanis you really should jump on it, cleans up the bike and gets you a couple ponies too.
    • Like Like x 3
  12. Chattanooga_Mark
    Dec 25, 2009
    5,390
    2,395
    Chattanooga
    2012 CCT, Wonderful in white
    Following @NOEMTZ recommendation exactly should be the quickest way to a resolution.
    • Agree Agree x 4
  13. McFousty
    McFousty New Member
    Aug 11, 2020
    13
    14
    Massachusetts
    2012 Victory Vegas
    No luck yet :/
  14. McFousty
    McFousty New Member
    Aug 11, 2020
    13
    14
    Massachusetts
    2012 Victory Vegas
    Slightly Older picture, about a week before my bike went into its current position I installed the Loydz torque tubes intake.
    • Like Like x 3
  15. McFousty
    McFousty New Member
    Aug 11, 2020
    13
    14
    Massachusetts
    2012 Victory Vegas
    • Winner Winner x 1
