Maximus hookup | Victory Motorcycles: Motorcycle Forums
Maximus hookup
Discussion in 'Tech Q&A' started by wickman, Apr 17, 2019.
  1. wickman
    wickman Active Member
    Jul 19, 2016
    713
    111
    Ontario
    Coud use a bit of help on the steps for setting up the Maximus and the TRO2 Wideband plug in's but more the Maximus. I have the Widebands screwed into the exhaust bungs. I've been reading the manual but seems to aim more to Harley's, the ecm only has a 60 pin connecter where as the connection from the Maximus has the 8 pin. I connected the Maximus to my laptop and nothing came up saying installing or recognizing it.
    Thanks for any help.
  2. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    5,534
    2,308
    Littlestown
    I had issues getting the program loaded in my laptop. Once I reloaded it everything worked. Good thing too I was getting ready to reach for my manual electronic adjustment tool ( BMFH).
    Good luck
    • Funny Funny x 3
  3. Andytwodogs
    Andytwodogs Well-Known Member
    Jan 17, 2014
    513
    264
    New England, NSW Australia
    '15 Cross Country LE
    My experience is more with the PVCX & wideband kit, but there is a diagnostic connector just under the ECU. It is plugged into a dummy socket. Just squeeze the clip and it will pop out. That is where the PVCX (and I assume the Maximus) plugs in.
  4. wickman
    Jul 19, 2016
    713
    111
    Ontario
    Ahh ok I seen a plug on an angle under the ecm, Thanks
  5. wickman
    Jul 19, 2016
    713
    111
    Ontario
    No problem with the program loading, its a newer Dell with windows 10.
  6. wickman
    Jul 19, 2016
    713
    111
    Ontario
    Ok think I'm getting somewhere, connected Maximus to computer and launched the Direct Link Button , not sure what happened but I can now access maps and view.
  7. wickman
    Jul 19, 2016
    713
    111
    Ontario
    Going to post the fuel tables and spark tables as well as Maximus , in case someone else is curious what they look like. front fuel table.jpg rear fuel table.jpg front spark table.jpg rear spark table.jpg maximus info.jpg
    • Winner Winner x 1
  8. cuppa
    cuppa New Member
    May 13, 2015
    14
    7
    Frankford Ontario (near Trenton)
    2015 Victory XCT
    • Funny Funny x 1
  9. wickman
    Jul 19, 2016
    713
    111
    Ontario
    Hi James, just being all I can be. :)
  10. wickman
    Jul 19, 2016
    713
    111
    Ontario
    Ok I have everything connected, tro2 widebands and maximus , key on and in run position and when I click Get ecu it shows the 2016 ecu like the photo but I don't see an option for backing up the stock ecu. before I load up a stage 1 map to tune in the Direct Link area of software. The Help files say to
    With the ignition switch on and the engine stop switch in the RUN position, click 'Get ECU Details' or select 'Backup Map' under the 'File' dropdown.. This will create a copy of the original ECU programming so that the motorcycle ECU can be restored to the memory condition it started in.Always save the original calibration before programming the new calibration. Select a location and name for the Backup Map and click on 'Save'. Direct Linkwill now read and save the original bike map.
    Would anyone be able to help with the Backing up of the original ECU pleas 57732340599__34412E48-9314-43CC-B0FB-3B7595CFC381.JPG e?
  11. waterhog
    waterhog Well-Known Member
    Sep 27, 2017
    724
    287
    Indiana
    '16 Victory Vegas
    Not sure what issue you’re encountering. Per Sec. 3.1 of the manual
    http://technoresearch.com/Manuals/DirectLinkUserManual.pdf
    it should be straightforward. If the File dropdown is not showing the backup option, just restart everything: power down software, bike, Maximus flash unit. Then start from scratch.
  12. wickman
    Jul 19, 2016
    713
    111
    Ontario
    Thanks for the proper instructions, the software instructions looks nothing like this.
  13. wickman
    Jul 19, 2016
    713
    111
    Ontario
    Ok don’t know what’s going on but that Backup button isn’t in my software. And the software is up to date and downloaded from techno research site.
  14. waterhog
    Sep 27, 2017
    724
    287
    Indiana
    '16 Victory Vegas
    In your last screen shot, not under File dropdown but at the bottom of the window, I see tabs for Backup, Open, Adjust, Save, etc. Check if they do anything.
  15. BP6666VR
    BP6666VR Well-Known Member
    Dec 23, 2013
    4,388
    1,832
    World Citizen
    Maximus hookup ....
    Are you saying you do not need a remote tuner ?
    Is it easier then the PCV ? Because i CANNOT make my PC300 to run properly and i am thinking about other options like remote tuning ...
    Very interesting topic
hooking up a maximus tuner to a victory cross contry
victory maxamus plug location
victory maximus plug location
