Maintenance on my wife's Renegade Saturday. Plugs, oil and filter, and air filter. Easy, right? Well, it would be pretty simple, except everything under the hood is either razor sharp or white hot.
Plugs first, cold engine. Spark plugs are NGK Iridium and Advance Auto didn't have them. Went to NAPA and they had them for $16 each. Gap is .028" or the tightest gap ever. The band clamps they use these days on all the hoses have a little excess band sticking out... and they are like little razor blades. I cut the corner off my thumbnail 1st thing. Be careful around those things. The swap itself was easy once you get the shroud off, anti-seize and dielectric grease (why I like to do these things myself) and air filter was easy too, it's right on top of the fender well.
Warm it up to change the oil. The oil filter is a cartridge type, which means removing the housing, replacing the cartridge and replacing the o-ring on the housing. To loosen the housing you need 2 extensions and 2 universal swivels to reach it. Once loose enough, you can get your hand in there to pull it out... all except it's right next to the turbo which is REALLY FREAKIN' HOT.
Maintenance got done... 2 burns and 3 cuts. Next oil change I'm wearing my welding gloves.
