not enough to keep it on the ground once you add cams and an underdrive pulley!!Anyone happen to know what the stock 21" magnum from wheel weighs?
See this where I'm confused! I've been told billet is stronger buy heavier. And I would assume it would be lighter too? Guess the only way to find out is to put them both on a scale.The billet X1 wheel is billet. It would be lighter than cast.
Billet aluminum vs cast aluminum.Aluminum vs Cast metal ? I think the billet may come in lighter. Would be interesting to see the difference.
YesYou think our wheels are cast aluminum. ?
cast aluminum might be cast a little thicker, so it'll be be heavier, but probably not by much. I think they do that to make it stronger, but I suppose it depends on the quality of the casting.Cast aluminum is most likely lighter than billet.
Yepper stock wheels are cast! Billet is much stronger which is the route I'm going, I was just curious as to which is lighter. Not like it really makes a difference just always wondered is allYou think our wheels are cast aluminum. ?
If you drop them both off a 2 story building ?Which weighs more, 1 pound of aluminum or 1 pound of feathers?![]()
