I removed my original baffles from my xbow exhaust cos I like the sound it produced but am loosing out a little on the low down torque that baffles offer . So I decided to make some lollipop baffles . I don't possess a welder so this was all done without welding . I went on ebay and got a motor exhaust company to make two stainless steel exhaust couplers to my spec which was 6 inches long over all . See spec below -
Custom Connector - 65mm OD to 65mm OD with custom length swages
1st Swage 1" Long, 2nd Swage 3" Long, Middle Section 2" Long, 57mm OD.
I bought a couple of stainless steel M8 thumb screws and two M8 s/s thin half lock nuts and two M8 s/s nuts . I then drilled a 7mm hole in the middle of the smaller section and tap threaded to 8mm , I added a nut to the thumb screw then screwed it inside the tube which was quite fiddly but makes the thumb screw more secure . Leave approximately 3mm proud on the outside of the coupling and fit the thin half nut , Tighten both nuts up . Drill a 5mm hole on the 1 inch end of the coupling to secure to your exhaust , tap thread it to 6mm if you do this it makes it very easy to screw in from the outside with no need to fiddle around trying to hold the nut on the inside of the pipe with a spanner .
Its given my exhaust a deeper sound a nice rumble not sure about any gain in the low down torque yet , maybe it has . Im forever the skeptic so not too sure . Perhaps when I go on more journeys I will notice the difference . Any way it can't do any harm .
