1 - 16 of 16 Posts
Got a loydz timing wheel coming for my 17 stock vision. Reading on here sounds like the vision doesn't take as much timing as other models. +3*. Is this because bike is heavier or does it have a bit of a different timing curve? Thanx in advance. Jeff V.
I don't know the answer but my 2013 Vision is running great at +4. You can see my minor mods in my sig. Try it. If it doesn't work out drop to three and try it again. There are a few of us here that are running at +4 so maybe you can be one of the lucky ones too.
If you don't address the lean issue first I would start at 3. Being as you are north of us you may be able to get away with 4.
Personally I would of gone with the upper filter and Maximus Turner. Then you wouldn't need the timing wheel.
Vision should run great on +4. The reason they don't take more timing is cause of the air flow to the throttle body.
Start at +4 you can go down to 3 in less then a 1/2 hour
1 - 16 of 16 Posts
